Saltar al contenido principal
Mi 11 Rear Glass Replacement
Qué necesitas
  1. Mi 11 Rear Glass Replacement, Heat the rear glass: paso 1, imagen 1 de 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Mi 11 Rear Glass Replacement, Insert an opening pick: paso 2, imagen 1 de 3 Mi 11 Rear Glass Replacement, Insert an opening pick: paso 2, imagen 2 de 3 Mi 11 Rear Glass Replacement, Insert an opening pick: paso 2, imagen 3 de 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Mi 11 Rear Glass Replacement, Slice the adhesive: paso 3, imagen 1 de 2 Mi 11 Rear Glass Replacement, Slice the adhesive: paso 3, imagen 2 de 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
  4. Mi 11 Rear Glass Replacement, Slice the adhesive: paso 4, imagen 1 de 3 Mi 11 Rear Glass Replacement, Slice the adhesive: paso 4, imagen 2 de 3 Mi 11 Rear Glass Replacement, Slice the adhesive: paso 4, imagen 3 de 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your Xiaomi Mi 11 to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Mi 11 Rear Glass Replacement: paso 5, imagen 1 de 2 Mi 11 Rear Glass Replacement: paso 5, imagen 2 de 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Mi 11 Rear Glass Replacement: paso 6, imagen 1 de 2 Mi 11 Rear Glass Replacement: paso 6, imagen 2 de 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
  7. Mi 11 Rear Glass Replacement, Remove the rear glass: paso 7, imagen 1 de 2 Mi 11 Rear Glass Replacement, Remove the rear glass: paso 7, imagen 2 de 2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Conclusión
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
2 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
229,784 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
119 Miembros
19,481 Guías creadas
Un comentario
, j'ai besoin d'une vitre arrière Xiaomi mi 11 bleu original
المتصدي 13 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 88
Ultimos 30 días: 263
Todo El Tiempo: 8,598
