Introducción
Use this guide to replace a broken trackpad.
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the following two screws:
One 5.6 mm Tri-point screw
One 13 mm Tri-point screw
Use the flat end of a spudger to carefully pry the trackpad connector up from its socket on the logic board.
If necessary, carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
Carefully push the trackpad connector and cable down through the slot cut into the upper case.
It may be necessary to use a spudger to help get the trackpad connector past the edge of the logic board.
Once the cable has been completely pulled through its slot in the upper case, pull the trackpad away from the outer edge of the upper case and remove it from the machine.
63 personas más completaron esta guía.
8 Comentarios
These are just the steps to remove the battery. For the trackpad itself see the Early 2011 Trackpad guide.
any tips on adjustment of the height screw?
don't turn the screw too much, or you'll destroy your trackpad
Is it possible to use Trackpad for Retina instead of Non-Retina Trackpad?
I had a lot of trouble getting the new trackpad to work. The left side of the track pad (about 2cm) was responsive. The rest of the track pad was dead. I played with the torx screw to adjust the click pressure and it had no effect. I cleaned all the gunk out from around the perimeter of the trackpad when it was removed. I tested without the battery in place to ensure that battery pressure was not the problem.
The actual hardware remove, reinstall took about 15 minutes at most and was very straight forward.
The trouble shooting has been the tough part.
