Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 5
If you are installing a replacement trackpad that didn't come with the attached flex cable, you'll need to use the cable from your old trackpad.
  • If you are installing a replacement trackpad that didn't come with the attached flex cable, you'll need to use the cable from your old trackpad.
  • To remove the flex cable from the old trackpad, first flip open the latch on the ZIF connector, opposite the cable. Then, apply a little heat from a hair dryer or iOpener to soften the adhesive securing the cable to the trackpad, and carefully peel off and remove the cable.
  • When installing your new trackpad, routing the cable through the upper case and past the logic board may be difficult. It is helpful to use the tip of a spudger to guide the connector past the logic board while pushing the cable through its slot in the upper case with your other hand.
Al instalar su nuevo trackpad , enrutar el cable a través de la caja superior y más allá de la placa lógica puede ser difícil. Es útil utilizar la punta de un spudger para guiar el conector mas allá de la placa lógica mientras empujas el cable a través de la ranura en la caja superior con la otra mano.
[* icon_note] If you are installing a replacement trackpad that didn't come with the attached flex cable, you'll need to use the cable from your old trackpad.
[* black] To remove the flex cable from the old trackpad, first flip open the latch on the [guide|25629|ZIF connector|stepid=64969|new_window=true], opposite the cable. Then, apply a little heat from a hair dryer or [guide|25705|iOpener|new_window=true] to soften the adhesive securing the cable to the trackpad, and carefully peel off and remove the cable.
[* icon_reminder] When installing your new trackpad, routing the cable through the upper case and past the logic board may be difficult. It is helpful to use the tip of a spudger to guide the connector past the logic board while pushing the cable through its slot in the upper case with your other hand.
