Saltar al contenido principal
MacBook Air SSD Replacement
Qué necesitas
  1. MacBook Air SSD Replacement, SSD: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Comprar
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case.
    • The two screws on the edge containing the hinge are longer than the others.
    • The eight screws in the corners and remaining edges are shorter.
  2. MacBook Air SSD Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air SSD Replacement: paso 3, imagen 1 de 2 MacBook Air SSD Replacement: paso 3, imagen 2 de 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air SSD Replacement: paso 4, imagen 1 de 1
    • Remove a single T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air SSD Replacement: paso 5, imagen 1 de 2 MacBook Air SSD Replacement: paso 5, imagen 2 de 2
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusión
Austin Blakely
Miembro Desde 03/11/19
19,527 Reputación
53 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,125 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 32
Ultimos 7 días: 177
Ultimos 30 días: 689
Todo El Tiempo: 2,675
