Saltar al contenido principal
MacBook Air 13" Retina Display 2019 Upper Case Replacement
Qué necesitas
  1. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the screws securing the lower case: paso 1, imagen 1 de 1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the lower case: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the battery: paso 3, imagen 1 de 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 4, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 4, imagen 2 de 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the right speaker adhesive: paso 5, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the right speaker adhesive: paso 5, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the right speaker adhesive: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
    • Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • If the adhesive strip breaks, leave it in and proceed to the next step.
  6. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 6, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 6, imagen 2 de 2
    • Slide the tip of a spudger underneath the right speaker cable and pry straight up to disconnect the speaker.
  7. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 7, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 7, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 7, imagen 3 de 3
    • Use tweezers to lift the adhesive pull tab at the top of the right speaker enough that you can grab it with your fingers.
    • If the adhesive strip breaks, or if the first adhesive strip broke, use a heated iOpener or heat gun to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  8. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the right speaker: paso 8, imagen 1 de 1
    • Lift the right speaker straight up from the bottom and remove it.
  9. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the left speaker adhesive: paso 9, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the left speaker adhesive: paso 9, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the left speaker adhesive: paso 9, imagen 3 de 3
    Comprar
    • Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the left speaker, enough so you can grab it with your fingers.
  10. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 10, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 10, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 10, imagen 3 de 3
    • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  11. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 11, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 11, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 11, imagen 3 de 3
    • Use tweezers to lift the adhesive pull tab at the top of the left speaker enough that you can grab it with your fingers.
  12. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the left speaker: paso 12, imagen 1 de 1
    • Lift the left speaker straight up from the bottom and remove it.
  13. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the right speaker: paso 13, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the right speaker: paso 13, imagen 2 de 2
    • Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
  14. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the audio board: paso 14, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the audio board: paso 14, imagen 2 de 2
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
    • Remove the cable bracket.
  15. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 15, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 15, imagen 2 de 2
    • Use the flat end of a spudger to pry the audio board connector straight up and disconnect it.
  16. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 16, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 16, imagen 2 de 2
    • Use the flat end of a spudger to pry the Touch ID sensor connector straight up and disconnect it.
  17. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the audio board: paso 17, imagen 1 de 1
    • Remove the following screws:
    • Two 4.3 mm, T5 Torx screws
    • One 2.4 mm, T3 Torx screw
  18. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 18, imagen 1 de 1
    • Slide the flat end of a spudger underneath the Touch ID sensor cable to slice through the adhesive securing it to the audio board.
  19. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 19, imagen 1 de 1
    • Remove the audio board.
  20. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the fan: paso 20, imagen 1 de 1
    • Peel back the black tape covering the fan cable connector.
  21. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 21, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 21, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 21, imagen 3 de 3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  22. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Separate the audio board cable: paso 22, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Separate the audio board cable: paso 22, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Separate the audio board cable: paso 22, imagen 3 de 3
    • Slide an opening pick under the audio board cable to slice through the adhesive securing it to the fan.
  23. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the fan: paso 23, imagen 1 de 1
    • Use a T5 Torx driver to remove the three 2.7 mm screws securing the fan.
  24. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 24, imagen 1 de 1
    • Lift the fan out of the case and remove it.
  25. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the antenna bar: paso 25, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the antenna bar: paso 25, imagen 2 de 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  26. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 26, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 26, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 26, imagen 3 de 3
    • Insert the point of a spudger under one of the antenna cables close to the connector.
    • Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  27. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 27, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 27, imagen 2 de 2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  28. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 28, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 28, imagen 2 de 2
    • Use the flat end of a spudger to pry up the display cable connector.
  29. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 29, imagen 1 de 1
    • Use a T5 Torx driver to remove the following screws:
    • Four 7.4 mm screws
    • Two 4.5 mm screws
  30. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the antenna bar: paso 30, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the antenna bar: paso 30, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the antenna bar: paso 30, imagen 3 de 3
    • Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
    • You may encounter resistance from the clips in the middle of the antenna bar holding it in the case. You may pull hard without damaging anything as long as you pull straight up, perpendicular to the case.
    • Remove the antenna bar.
  31. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the display: paso 31, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the display: paso 31, imagen 2 de 2
    • Use a T9 Torx driver to remove the six 4.9 mm screws securing the display hinges to the upper case.
  32. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 32, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 32, imagen 2 de 2
    • With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
  33. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 33, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 33, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 33, imagen 3 de 3
    • Lift the MacBook and carefully rotate the display to a 90 degree angle with the upper case.
    • The hinges should not move in relation to the display, and should rotate out of the case slightly.
    • Keeping the display at a 90 degree angle with the case, move the display straight down while holding the case still, so that the hinges slide out the bottom of the case.
  34. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the Touch ID sensor: paso 34, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the Touch ID sensor: paso 34, imagen 2 de 2
    • Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
    • Remove the Touch ID bracket.
  35. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 35, imagen 1 de 1
    • Turn the MacBook right-side up and open the display.
    • Lift the Touch ID sensor sensor out of its recess and remove it.
  36. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the USB-C board: paso 36, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the USB-C board: paso 36, imagen 2 de 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector bracket.
    • Remove the USB-C connector bracket.
  37. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 37, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 37, imagen 2 de 2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  38. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 38, imagen 1 de 1
    • Use a T4 Torx driver to remove the two 2.9 mm screws securing the USB-C board.
  39. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 39, imagen 1 de 1
    • Remove the USB-C board.
  40. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the trackpad cable: paso 40, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the trackpad cable: paso 40, imagen 2 de 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
    • Remove the trackpad connector bracket.
  41. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 41, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 41, imagen 2 de 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  42. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the audio board cable: paso 42, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the audio board cable: paso 42, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the audio board cable: paso 42, imagen 3 de 3
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  43. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Unscrew the logic board: paso 43, imagen 1 de 1
    • One 5.5 mm screw
    • Three 2.6 mm screws
    • Two 1.9 mm screws
  44. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the logic board: paso 44, imagen 1 de 1
    • Remove the logic board.
  45. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Separate the trackpad cable adhesive: paso 45, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Separate the trackpad cable adhesive: paso 45, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Separate the trackpad cable adhesive: paso 45, imagen 3 de 3
    • Carefully slide an opening pick under the trackpad cable to separate the adhesive securing it to the upper case.
    • If you have difficulty separating the adhesive, heat it slightly with an iOpener or hair dryer to soften the adhesive.
  46. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the trackpad cable: paso 46, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the trackpad cable: paso 46, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the trackpad cable: paso 46, imagen 3 de 3
    • Use the flat end of a spudger to lift the small locking flap on the trackpad ZIF connector.
    • Slide the trackpad cable straight out of its connector.
  47. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Separate the trackpad cable adhesive: paso 47, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Separate the trackpad cable adhesive: paso 47, imagen 2 de 2
    • Carefully slide an opening pick under the trackpad cable to separate the adhesive securing it to the battery.
    • If you have difficulty separating the adhesive, heat it slightly with an iOpener or hair dryer. Be careful not to overheat the battery.
  48. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the trackpad: paso 48, imagen 1 de 1
    • Use a T5 Torx driver to remove the following screws securing the trackpad:
    • One 3.2 mm screw
    • Eight 3.1 mm screws
  49. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 49, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 49, imagen 2 de 2
    • With the laptop still lying screen-side down, carefully open the laptop. The trackpad will stay sitting on the display.
    • Remove the trackpad from the MacBook. Take care not to scratch the display.
  50. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the trackpad cable: paso 50, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the trackpad cable: paso 50, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Disconnect the trackpad cable: paso 50, imagen 3 de 3
    • Use the flat end of a spudger to lift the small locking flap on the trackpad's ZIF connector.
    • Slide the trackpad cable straight out of the ZIF connector.
  51. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Unscrew the battery: paso 51, imagen 1 de 1
    • Use a T3 Torx driver to remove four 2.5 mm screws securing the battery.
  52. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the battery adhesive: paso 52, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the battery adhesive: paso 52, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the battery adhesive: paso 52, imagen 3 de 3
    Comprar
    • Use a pair of tweezers to lift up the black adhesive pull tab on the side of the battery, enough so you can grab it with your fingers.
    • Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the battery.
  53. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 53, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 53, imagen 2 de 2
    • Repeat the previous step to remove the next two adhesive strips on the same side of the battery.
    • If any adhesive strips break, leave them in and proceed to the next step.
  54. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 54, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 54, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 54, imagen 3 de 3
    • Repeat the previous two steps to remove the three adhesive strips on the other side of the battery.
    • If any of the adhesive strips broke, you can use high-concentration (>90%) isopropyl alcohol to help remove them:
    • Carefully drip isopropyl alcohol along either edge of the battery, in the recessed part of the upper case, where the adhesive pull tabs were.
    • Applying too much alcohol or applying it outside of the wells in the case where the adhesive sits risks damaging other components.
    • Let the alcohol soak into the adhesive for a minute or two.
    • Use opening picks to gently pry the battery away from the upper case.
  55. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the battery: paso 55, imagen 1 de 1
    • Remove the battery.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  56. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the microphone assembly: paso 56, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the microphone assembly: paso 56, imagen 2 de 2
    • Slide an opening pick under the microphone farthest away from the edge of the case to slice through the adhesive securing it to the upper case.
    • The microphone assembly is still connected to the case. Do not try to remove the microphone assembly or lift the cable.
    • If the adhesive is stubborn, do not force the pick. Heat the microphone assembly using an iOpener or a hair dryer to soften the adhesive.
  57. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 57, imagen 1 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 57, imagen 2 de 3 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 57, imagen 3 de 3
    • Use the point of a spudger to lift the small locking flap on the microphone's ZIF connector.
    • Slide the microphone cable straight out of the ZIF connector.
  58. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 58, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 58, imagen 2 de 2
    • Slide an opening pick under the rest of the microphone assembly cable to separate it from the adhesive securing it to the upper case.
  59. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 59, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 59, imagen 2 de 2
    • Use the point of a spudger to carefully pry one of the microphones out of its recess in the upper case.
    • If the adhesive is stubborn, it may be necessary to apply heat to the microphone or the case.
  60. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 60, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 60, imagen 2 de 2
    • Use the point of a spudger to carefully pry the other microphone out of its recess in the upper case.
  61. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 61, imagen 1 de 1
    • Remove the microphone assembly.
  62. MacBook Air 13" Retina Display 2019 Upper Case Replacement, Remove the USB-C port brackets: paso 62, imagen 1 de 1
    • Use a P2 pentalobe driver to remove the two 1.1 mm screws securing the USB-C port brackets.
  63. MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 63, imagen 1 de 2 MacBook Air 13" Retina Display 2019 Upper Case Replacement: paso 63, imagen 2 de 2
    • Lift the USB-C port brackets out of their recesses in the upper case and remove them.
    • Compare your new upper case to your old one and transfer over any remaining parts.
Conclusión
4 personas más completaron esta guía.
Adam O'Camb
Miembro Desde 04/11/15
196,940 Reputación
416 Guías creadas
2 comentarios
Saw one for cheap with a bad keyboard and battery. I think I'm gonna pass lmao
Michael Verant - Contestar
When reassembling the device, what does one do about all of the removed adhesive? Is it reusable, or is there some kind of recommended replacement material?
Michael Ashburne - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 33
Ultimos 30 días: 163
Todo El Tiempo: 6,638
