Introducción
This guide will demonstrate how to replace the battery in your Lenovo ThinkPad X395.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Qué necesitas
Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
Orient your laptop so that the screen's silver hinges are closest to you.
Insert an opening pick between the back cover and the device body near a hinge corner.
Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
Lift and remove the cover up from the laptop, starting with the edge nearest to you.
Shift the cover side to side if the center clip feels stuck.
Grab the battery pull-tab on the head of the connector.
Pull the connector out of its socket in the direction of the cable.
Use your Phillips screwdriver to remove the four 5.3 mm-long screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
