Introducción
Follow this guide to replace a broken or damaged base cover (or back cover) for your Lenovo ThinkPad T16 Gen 3 laptop.
The Lenovo part number for the base cover is 5CB1M21641 for the WLAN model and 5CB1M21650 for the WWAN model.
Qué necesitas
Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
Pry up the base cover until the clips unfasten.
Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
Lift and remove the base cover.
