Introducción
Use this guide to replace the battery in your Lenovo ThinkPad T15 Gen 2 Laptop.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Qué necesitas
Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
Insert an opening pick between the lower case and the chassis on the front right edge.
Angle the pick down at about 30˚.
Slide the pick along the front edge to release the clips securing the lower case.
Insert an opening tool between the lower case and the chassis, just to the right of the USB port on the left edge.
Pry the opening case up to release the clip next to the USB port.
Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
Use a Phillips #0 screwdriver to remove the three 5.4 mm-long screws securing the battery.
Push the battery toward the top of the laptop to release its plastic clips.
Lift the battery straight out of its recess and remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
