Saltar al contenido principal
Knot Thread to the Fabric (2 Ways)
Qué necesitas
  1. Knot Thread to the Fabric (2 Ways), Secure knot type 1: paso 1, imagen 1 de 3 Knot Thread to the Fabric (2 Ways), Secure knot type 1: paso 1, imagen 2 de 3 Knot Thread to the Fabric (2 Ways), Secure knot type 1: paso 1, imagen 3 de 3
    • On the backside of the fabric, make a very small stitch.
    • Pull the thread through, leaving a short tail of approximately 1/2 inch (~13 mm) to 1 inch (~25 mm).
    • Make another small stitch in the same area. Leave the needle piercing the fabric without pulling it all the way through.
  2. Knot Thread to the Fabric (2 Ways): paso 2, imagen 1 de 3 Knot Thread to the Fabric (2 Ways): paso 2, imagen 2 de 3 Knot Thread to the Fabric (2 Ways): paso 2, imagen 3 de 3
    • Take the thread that's emerging from the stitch and wrap it around the needle.
    • Wrap the thread around the needle a second time.
    • Push the wrapped threads down towards the base of the needle where it's emerging from the fabric.
  3. Knot Thread to the Fabric (2 Ways): paso 3, imagen 1 de 1
    • Pull the needle through the loops and pull the thread tight. The knot will lay flush with the fabric.
    • This video shows how to start a stitch with secure knot type 1.
    • This video shows how to end a stitch with secure knot type 1.
  4. Knot Thread to the Fabric (2 Ways), Secure knot type 2: paso 6, imagen 1 de 2 Knot Thread to the Fabric (2 Ways), Secure knot type 2: paso 6, imagen 2 de 2
  5. Knot Thread to the Fabric (2 Ways): paso 7, imagen 1 de 2 Knot Thread to the Fabric (2 Ways): paso 7, imagen 2 de 2
    • Make another small stitch in the same area, across the first stitch.
    • Pull the thread through but don't pull it tight, leaving a small loop.
  6. Knot Thread to the Fabric (2 Ways): paso 8, imagen 1 de 2 Knot Thread to the Fabric (2 Ways): paso 8, imagen 2 de 2
    • Thread the needle through the loop that was created in the previous step.
    • Gently pull the needle through the loop without pulling the thread tight, keeping the thread loop intact.
  7. Knot Thread to the Fabric (2 Ways): paso 9, imagen 1 de 2 Knot Thread to the Fabric (2 Ways): paso 9, imagen 2 de 2
    • Thread the needle through the loop again in the same direction as the previous step.
    • Pull the thread tight to secure the knot. The knot will lay flush against the fabric.
    • This video shows how to start a stitch with secure knot type 2.
    • This video shows how to end a stitch with secure knot type 2.
Linea de Meta
Una persona más ha completado esta guía.
Clara Redwood
Miembro Desde 11/12/24
2,544 Reputación
18 Guías creadas
Equipo
Patagonia Miembro de Patagonia
Community
Miembros de 17
168 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 27
Ultimos 30 días: 113
Todo El Tiempo: 510
