Saltar al contenido principal
Huawei P10 Lite Display Assembly with Frame Replacement
Qué necesitas
  1. Huawei P10 Lite Display Assembly with Frame Replacement, Back cover: paso 1, imagen 1 de 3 Huawei P10 Lite Display Assembly with Frame Replacement, Back cover: paso 1, imagen 2 de 3 Huawei P10 Lite Display Assembly with Frame Replacement, Back cover: paso 1, imagen 3 de 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Display Assembly with Frame Replacement: paso 2, imagen 1 de 3 Huawei P10 Lite Display Assembly with Frame Replacement: paso 2, imagen 2 de 3 Huawei P10 Lite Display Assembly with Frame Replacement: paso 2, imagen 3 de 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Display Assembly with Frame Replacement: paso 3, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Display Assembly with Frame Replacement: paso 4, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement: paso 4, imagen 2 de 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Display Assembly with Frame Replacement, Battery Disconnection: paso 5, imagen 1 de 3 Huawei P10 Lite Display Assembly with Frame Replacement, Battery Disconnection: paso 5, imagen 2 de 3 Huawei P10 Lite Display Assembly with Frame Replacement, Battery Disconnection: paso 5, imagen 3 de 3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Display Assembly with Frame Replacement, Battery: paso 6, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement, Battery: paso 6, imagen 2 de 2
    • Use an iOpener to loosen the adhesive beneath the battery.
    • Insert a spudger between the battery and the mid frame to create a gap.
    • Be careful not to puncture or crease the battery.
    • Insert an opening pick or use the spuder in the gap to cut the adhesive beneath the battery.
    • There are flex cables running under the battery. Don't damage them with your tools.
  7. Huawei P10 Lite Display Assembly with Frame Replacement: paso 7, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement: paso 7, imagen 2 de 2
    Tesa 61395 Tape
    $5.99
    Comprar
    • Use a spudger to cut the rest of the adhesive and lever the battery out of the phone.
    • Remove the battery.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
    • Never reinstall a battery that has been bent or damaged during removal.
  8. Huawei P10 Lite Display Assembly with Frame Replacement, SIM Card Tray: paso 8, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement, SIM Card Tray: paso 8, imagen 2 de 2
    • Use a SIM card removal bit or tool and push it into the small hole in the SIM card tray.
    • Remove the SIM card tray.
  9. Huawei P10 Lite Display Assembly with Frame Replacement, Display Assembly with Frame: paso 9, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement, Display Assembly with Frame: paso 9, imagen 2 de 2
    Comprar
    • Remove the two Phillips screws.
    • Remove the display flex cable bracket with tweezers.
  10. Huawei P10 Lite Display Assembly with Frame Replacement: paso 10, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement: paso 10, imagen 2 de 2
    • Use a spudger to disconnect the headphone jack flex cable.
    • Altough the headphone jack is not glued to the mid frame it is a little bit tucked in its bracket. Be careful not to damage it during the removal.
    • Remove the headphone jack.
  11. Huawei P10 Lite Display Assembly with Frame Replacement: paso 11, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement: paso 11, imagen 2 de 2
    • Use a spudger to disconnect the rear camera flex cable.
    • Remove the rear camera.
  12. Huawei P10 Lite Display Assembly with Frame Replacement: paso 12, imagen 1 de 3 Huawei P10 Lite Display Assembly with Frame Replacement: paso 12, imagen 2 de 3 Huawei P10 Lite Display Assembly with Frame Replacement: paso 12, imagen 3 de 3
    • Use a spudger to disconnect the volume and power button, the display and the main flex cable.
  13. Huawei P10 Lite Display Assembly with Frame Replacement: paso 13, imagen 1 de 3 Huawei P10 Lite Display Assembly with Frame Replacement: paso 13, imagen 2 de 3 Huawei P10 Lite Display Assembly with Frame Replacement: paso 13, imagen 3 de 3
    • Unplug the antenna cable with tweezers.
    • The solder joints of some antenna cables might be weak so be careful not to break it out of the motherboard.
    • Use an opening pick to pry out the motherboard until you can get a good grip.
    • The front camera is still attached to the motherboard. Don't damage it during the motherboard removal.
    • Remove the motherboard.
    • On the back of the motherboard there are thermal pads (pink rubber-like gobs) for heat dissipation. If these thermal pads broke or are too dried out you might need to apply new thermal pads on the new display assembly or the motherboard.
  14. Huawei P10 Lite Display Assembly with Frame Replacement: paso 14, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement: paso 14, imagen 2 de 2
    • Remove the earpiece speaker with tweezers.
    • Use tweezers to remove the plastic cover of the volume and power button flex cable.
  15. Huawei P10 Lite Display Assembly with Frame Replacement: paso 15, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement: paso 15, imagen 2 de 2
    • Use an opening pick to cut the adhesive between the volume and power button flex cable and the mid frame.
    • The volume and power button flex cable is a little bit sticky and hard to remove. It can rip easily during the removal. You can use an iOpener to loosen the adhesive a little bit.
    • Carefully remove the volume and power button flex cable with tweezers.
  16. Huawei P10 Lite Display Assembly with Frame Replacement: paso 16, imagen 1 de 1
    • Remove the eight Phillips #00 screws securing the loudspeaker.
  17. Huawei P10 Lite Display Assembly with Frame Replacement: paso 17, imagen 1 de 2 Huawei P10 Lite Display Assembly with Frame Replacement: paso 17, imagen 2 de 2
    • Insert an opening pick under the loudspeaker unit and lever it up until you can get a good grip.
    • Remove the loudspeaker.
  18. Huawei P10 Lite Display Assembly with Frame Replacement: paso 18, imagen 1 de 3 Huawei P10 Lite Display Assembly with Frame Replacement: paso 18, imagen 2 de 3 Huawei P10 Lite Display Assembly with Frame Replacement: paso 18, imagen 3 de 3
    Tesa 61395 Tape
    $5.99
    Comprar
    • Use the flat end of a spudger to disconnect the interconnect cable and remove it.
    • Use tweezers to disconnect the antenna cable and remove it.
    • Remove the charging board with tweezers.
    • If you're having trouble whilst removing the charging board you can use an iOpener to loosen the adhesive beneath it.
    • Before reassembly check your new part for any components that might need to be transferred from the old one. Also check if new thermal pads (pink rubber-like gobs) need to be applied.
Conclusión
12 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
211,821 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,084 Guías creadas
4 comentarios
Hello!
Thanks for the assembly guide! My phones display glass was broken, and I bought new display with frame (since the frame might have been bent), and this guide proved to be helpful. Though, I ought to mention that you did not show how the upper left metal cover for display port was removed (not that I needed it).
However, I think I slightly damaged the main cord between upper and lower motherboards, the orange one, when I was removing the battery. I can still recharge my phone and listen to music through loudspeaker, but I can not hear or be heard when I am having a phone call with someone. I can use hands-free with a microphone to get around the problem, but I wanted to ask that is it possible for the damaged cord to cause this problem, or could it be something else? I would imagine that I should at least hear the other person even if the cord is slightly damaged.
- Jesse
Jesse Hettula - Contestar
Hello Jesse
It could be, that cable sends data from the top to the bottom. The micro of the calls is the lower one, so the information could not reach the top if that part is damaged. Look at step 17, in that small plate is the microphone, it could be covered by dirt or not embedded in its hole. But the headset does not depend on that cable, could it have misplaced the headset? Look at step 13, if it is reversed, it will not work.
Oscar -
Hello all!
As we continue getting more and more boards with the same problem, I’d like to point out that you should be very careful when disconnecting the antenna cable. The soldering quality is probably not the best, and this may lead to the antenna cable coming out of the board along with the connector to which it is connected.. This is not so critical, but you will have to do some jewelry work to solder the detached connector.
iliazt - Contestar
Thank you for the good guide which helped us to save my son’s phone!
P.S.: I recommend buying the spare parts here - I had ordered the first display on ebay (this was before my brother recommended ifixit to me) and it was broken. The parts from ifixit came in perfect quality.
Stefan Krokowski - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 13,307
