Introducción
Follow this guide to remove and replace the lithium-ion battery for the Mate 10. You also have to remove the battery in order to replace the screen.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
The back cover is held in place with a very strong perimeter adhesive. During removal, the adhesive may rip out parts of the coating from the glass back cover, leaving behind patches of clear glass.
Qué necesitas
Heat an iOpener and apply it to the bottom edge of the phone for two minutes. Re-heat the iOpener as needed.
While you wait, note the location of the adhesive holding the back cover in place.
You may pull up chunks of the cover's color coating as you remove the adhesive. To reduce the chances of this occurring, apply heat or high concentration isopropyl alcohol to the adhesive to weaken it.
Remove the eight 3.4 mm long Phillips screws securing the plastic bracket.
Insert the point of a spudger underneath the right edge of the plastic bracket and pry up slightly to loosen the shield.
Grasp the the lower edge of the plastic bracket with your fingers and lift the edge up slightly.
Pull the plastic bracket away from the top edge of the phone.
Slowly peel the black heat dissipation layer away from the phone. It is held in place with small patches of adhesive.
Remove the plastic bracket along with the heat dissipation layer.
Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
Use the point of a spudger to pry up and disconnect the wide interconnect flex cable from its motherboard socket.
Use the point of a spudger to pry up and disconnect the button connector from its motherboard socket.
Apply a heated iOpener to the left side of the phone screen for a minute.
While you wait, note where the U-shaped adhesive resides on the phone frame.
Herramienta utilizada en este paso:Plastic Cards$2.99
Insert a plastic card under the battery's right edge.
Push the card inwards to loosen the battery from the frame.
If you're having a hard time loosening the battery, you can apply more isopropyl alcohol, or try to soften the adhesive with more heat.
Once the battery is sufficiently loosened from the frame, slowly lift it out.
Remove the battery.
Apply new adhesive to the phone frame.
Gently lay the battery pack in the phone.
Temporarily reconnect the battery to the motherboard to ensure that the battery is properly aligned.
Once the battery is aligned, press it firmly in place with your fingers. Disconnect the battery from the motherboard, and resume re-assembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mate 10 Answers community for help.
6 personas más completaron esta guía.
6 comentarios
Excellent Guide!!! Very clear and detailed.. I replaced the battery on my Mate 10 in just 30 min without any problems.. Thank you!!!
Fantastic guide, Thanks!
Buongiorno! Infatti questa guida è stata scritta per lo Huawei Mate 10. Se guardi bene questa foto, vedi il numero di modello ALP-L29 che corrisponde al Mate 10. Invece, siccome i due telefoni son molto simili, puoi seguire le stesse istruzioni per ripararli. Ma non devi! Ci sono qui le guide per il Mate 10 Pro.
Muchas gracias, excelente información me ayudó muchísimo.
