Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Apply New Back Glass Adhesive in Your Google Pixel Fold
Qué necesitas
  1. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: paso 1, imagen 1 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: paso 1, imagen 2 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: paso 1, imagen 3 de 3
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
    • Look for cutouts in the liner to help orient the adhesive.
  2. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: paso 2, imagen 1 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: paso 2, imagen 2 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: paso 2, imagen 3 de 3
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel off the new adhesive strip from its clear liner.
    • Align the adhesive over the frame, starting with the top right and bottom right edges.
    • Place the adhesive over the perimeter of the frame.
  3. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 3, imagen 1 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 3, imagen 2 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 3, imagen 3 de 3
    • Use flat end of a spudger, or your fingers, to press down the adhesive to adhere it to the frame.
  4. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the large liner: paso 4, imagen 1 de 2 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the large liner: paso 4, imagen 2 de 2
    • Peel up the segmented tab at the bottom right corner of the large blue liner.
  5. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 5, imagen 1 de 2 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 5, imagen 2 de 2
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
  6. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Reconnect the back glass: paso 6, imagen 1 de 2 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Reconnect the back glass: paso 6, imagen 2 de 2
    • Support the back glass with your hand or prop it up on something sturdy.
    • Reconnect the back glass cable.
    • Use a Torx Plus 3IP driver to refasten the middle bracket.
  7. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the secondary liner: paso 7, imagen 1 de 2 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the secondary liner: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use tweezers, or your fingers, to peel up either one of the tabs at the top right corner of the secondary liner.
    • If the adhesive starts separating, use a spudger to hold it down while peeling.
  8. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 8, imagen 1 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 8, imagen 2 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 8, imagen 3 de 3
    • Lift the tab and peel off the secondary liner to expose the top adhesive.
  9. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: paso 9, imagen 1 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: paso 9, imagen 2 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: paso 9, imagen 3 de 3
    • Align the back glass over its cutout in the frame.
    • Place a long edge of the back glass on the frame, making sure there are no gaps or jutting adhesive.
    • Place the other long edge of the back glass on the frame.
  10. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 10, imagen 1 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 10, imagen 2 de 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: paso 10, imagen 3 de 3
    • Press down along the perimeter of the back glass to adhere it to the frame.
    • Let the phone sit a few hours for the adhesive to cure.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
Una persona más ha completado esta guía.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
234,329 Reputación
1,139 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 124
25,206 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 707
