Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Google Pixel Fold Base Battery Replacement
Qué necesitas
  1. Google Pixel Fold Base Battery Replacement, Safety Precautions: paso 1, imagen 1 de 1
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Pregunta a FixBot
    Agregar Comentario
  2. Google Pixel Fold Base Battery Replacement, Heat the bottom edge: paso 2, imagen 1 de 1
    • Lay the phone down on a clean, smooth surface so the back glass is facing up.
    • Heat an iOpener and apply it to the bottom edge of the back glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the displays and/or internal batteries, so proceed with care.
    Pregunta a FixBot
    Agregar Comentario
  3. Google Pixel Fold Base Battery Replacement, Anti-Clamp instructions: paso 3, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Anti-Clamp instructions: paso 3, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Anti-Clamp instructions: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Unfold your phone completely and slide the Anti-Clamp arms over the left edge of the back glass, below the Google "G" logo.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Make sure the suction cup on the inner screen isn't touching the bezel, as it won't stick properly.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface. If the glass if cracked, use packing tape to help the suction cups adhere.
    Pregunta a FixBot
    Agregar Comentario
  4. Google Pixel Fold Base Battery Replacement: paso 4, imagen 1 de 3 Google Pixel Fold Base Battery Replacement: paso 4, imagen 2 de 3 Google Pixel Fold Base Battery Replacement: paso 4, imagen 3 de 3
    • Place an object under your phone, like a box or a stack of books, so it rests level while between the Anti-Clamp's arms.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, detach the suction cups and realign the arms.
    Pregunta a FixBot
    Agregar Comentario
  5. Google Pixel Fold Base Battery Replacement: paso 5, imagen 1 de 1
    • Insert an opening pick into the gap under the back glass.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Pregunta a FixBot
    Agregar Comentario
  6. Google Pixel Fold Base Battery Replacement, Insert an opening pick: paso 6, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Insert an opening pick: paso 6, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Insert an opening pick: paso 6, imagen 3 de 3
    • Apply a suction cup to the back glass, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back glass and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back glass.
    Pregunta a FixBot
    Agregar Comentario
  7. Google Pixel Fold Base Battery Replacement, Separate the bottom adhesive: paso 7, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Separate the bottom adhesive: paso 7, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Separate the bottom adhesive: paso 7, imagen 3 de 3
    • Don’t insert the opening pick deeper than 3.5 mm when separating the back glass adhesive, as you risk damaging internal components.
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom left corner before continuing.
    Pregunta a FixBot
    Agregar Comentario
  8. Google Pixel Fold Base Battery Replacement, Heat the left edge: paso 8, imagen 1 de 1
    • Apply a heated iOpener to the left edge of the back glass for two minutes.
    Pregunta a FixBot
    Agregar Comentario
  9. Google Pixel Fold Base Battery Replacement, Separate the bottom left adhesive: paso 9, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Separate the bottom left adhesive: paso 9, imagen 2 de 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
    Pregunta a FixBot
    Agregar Comentario
  10. Google Pixel Fold Base Battery Replacement, Separate the left adhesive: paso 10, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Separate the left adhesive: paso 10, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Separate the left adhesive: paso 10, imagen 3 de 3
    • Insert a second opening pick at the bottom left corner.
    • Slide the opening pick toward the top left corner to separate the adhesive.
    • Leave the opening pick in the top left corner before continuing.
    Pregunta a FixBot
    Agregar Comentario
  11. Google Pixel Fold Base Battery Replacement, Heat the top edge: paso 11, imagen 1 de 1
    • Apply a heated iOpener to the top edge of the back glass for two minutes.
    Pregunta a FixBot
    Agregar Comentario
  12. Google Pixel Fold Base Battery Replacement, Separate the top left adhesive: paso 12, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Separate the top left adhesive: paso 12, imagen 2 de 2
    • Rotate the opening pick around the top left corner to separate the adhesive.
    Pregunta a FixBot
    Agregar Comentario
  13. Google Pixel Fold Base Battery Replacement, Separate the top adhesive: paso 13, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Separate the top adhesive: paso 13, imagen 2 de 2
    • Insert a third opening pick in the top left corner.
    • Slide the opening pick toward the top right corner to separate the adhesive.
    Pregunta a FixBot
    Agregar Comentario
  14. Google Pixel Fold Base Battery Replacement, Heat the right edge: paso 14, imagen 1 de 1
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    Pregunta a FixBot
    Agregar Comentario
  15. Google Pixel Fold Base Battery Replacement, Separate the top right adhesive: paso 15, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Separate the top right adhesive: paso 15, imagen 2 de 2
    • This sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
    • Angle your pick so it's as flat as possible to the back glass.
    • Rotate the opening pick around the top right corner to separate the adhesive.
    Pregunta a FixBot
    Agregar Comentario
  16. Google Pixel Fold Base Battery Replacement, Separate the right adhesive: paso 16, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Separate the right adhesive: paso 16, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Separate the right adhesive: paso 16, imagen 3 de 3
    • Insert a fourth opening pick in the top right corner.
    • Slide the opening pick toward the bottom right corner to separate the adhesive.
    Pregunta a FixBot
    Agregar Comentario
  17. Google Pixel Fold Base Battery Replacement, Separate the bottom right adhesive: paso 17, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Separate the bottom right adhesive: paso 17, imagen 2 de 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
    Pregunta a FixBot
    Agregar Comentario
  18. Google Pixel Fold Base Battery Replacement, Reposition the back glass: paso 18, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Reposition the back glass: paso 18, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Reposition the back glass: paso 18, imagen 3 de 3
    • Don't fully remove the back glass yet, as it's still connected to the phone by a cable.
    • At this point, the back glass should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Swing the left edge of the back glass up and over the right edge of the phone.
    • Lay the back glass to the right side of the phone before continuing.
    Pregunta a FixBot
    Agregar Comentario
  19. Google Pixel Fold Base Battery Replacement, Unfasten the middle bracket: paso 19, imagen 1 de 1
    FixMat
    $36.95
    • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the two 2.8 mm‑long screws securing the middle bracket.
    Pregunta a FixBot
    Agregar Comentario
  20. Google Pixel Fold Base Battery Replacement, Remove the middle bracket: paso 20, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Remove the middle bracket: paso 20, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Remove the middle bracket: paso 20, imagen 3 de 3
    • Use tweezers, or your fingers, to pull the middle bracket toward the left edge of the phone and release its clip.
    • Remove the middle bracket.
    • During reassembly, reinsert the middle bracket clip under its slot in the frame before aligning the screw holes.
    Pregunta a FixBot
    Agregar Comentario
  21. Google Pixel Fold Base Battery Replacement, Disconnect the back glass cable: paso 21, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Disconnect the back glass cable: paso 21, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the back glass cable from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Pregunta a FixBot
    Agregar Comentario
  22. Google Pixel Fold Base Battery Replacement, Remove the back glass: paso 22, imagen 1 de 1
    • Remove the back glass.
    Pregunta a FixBot
    Agregar Comentario
  23. Google Pixel Fold Base Battery Replacement, Reassembly information: paso 23, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Reassembly information: paso 23, imagen 2 de 2
    Tesa 61395 Tape
    $8.95
    • During reassembly:
    • If you're reusing your back glass, use tweezers to remove big chunks of adhesive from the perimeter of the back glass.
    • Repeat for any adhesive on the frame.
    • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • Follow this guide to replace the back glass adhesive with custom cut strips.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the back glass to the frame.
    Pregunta a FixBot
    Agregar Comentario
  24. Google Pixel Fold Base Battery Replacement, Reposition the graphite sheet: paso 24, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Reposition the graphite sheet: paso 24, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Reposition the graphite sheet: paso 24, imagen 3 de 3
    Tesa 61395 Tape
    $8.95
    • The graphite sheet is very fragile. Be gentle peeling the graphite sheet in this step, especially if you're reusing it.
    • The graphite sheet is lightly adhered to the logic board.
    • Peel the bottom of the graphite sheet toward the top of the phone until you can access the bottom bracket.
    • Use your hands, or tape with light adhesive, to keep the graphite sheet out of the way.
    • If you completely removed your graphite sheet, follow this guide to replace it.
    • If you don't have custom cut adhesive strips for the antenna, use double-sided tape, like Tesa Tape, to secure the graphite sheet to the logic board.
    Pregunta a FixBot
    Agregar Comentario
  25. Google Pixel Fold Base Battery Replacement, Remove the screw cover: paso 25, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Remove the screw cover: paso 25, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Remove the screw cover: paso 25, imagen 3 de 3
    Pregunta a FixBot
    Agregar Comentario
  26. Google Pixel Fold Base Battery Replacement, Unfasten the bottom bracket: paso 26, imagen 1 de 1
    • Use a Torx Plus 3IP driver to remove the five 3.1 mm‑long screws securing the bottom bracket.
    Pregunta a FixBot
    Agregar Comentario
  27. Google Pixel Fold Base Battery Replacement, Remove the bottom bracket: paso 27, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Remove the bottom bracket: paso 27, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Remove the bottom bracket: paso 27, imagen 3 de 3
    • Use tweezers, or your fingers, to pull the bottom bracket toward the bottom edge of the phone and release its clip.
    • Remove the bottom bracket.
    • During reassembly, reinsert the bottom bracket clip under its slot in the logic board before aligning its screw holes.
    Pregunta a FixBot
    Agregar Comentario
  28. Google Pixel Fold Base Battery Replacement, Disconnect the base battery: paso 28, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Disconnect the base battery: paso 28, imagen 2 de 2
    • There are two batteries you need to disconnect, one for each half of the phone.
    • Use the point of a spudger to pry up and disconnect the base battery cable press connector.
    Pregunta a FixBot
    Agregar Comentario
  29. Google Pixel Fold Base Battery Replacement, Remove the tape: paso 29, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Remove the tape: paso 29, imagen 2 de 2
    • Peel the grey conductive tape off the bottom interconnect cable.
    Pregunta a FixBot
    Agregar Comentario
  30. Google Pixel Fold Base Battery Replacement, Disconnect the flip battery: paso 30, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Disconnect the flip battery: paso 30, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Disconnect the flip battery: paso 30, imagen 3 de 3
    • Use a point of a spudger to pry up and disconnect the flip battery and bottom interconnect press connectors.
    • You have to disconnect both cables to keep the battery connector from accidentally touching the logic board.
    Pregunta a FixBot
    Agregar Comentario
  31. Google Pixel Fold Base Battery Replacement, Reassembly information: paso 31, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Reassembly information: paso 31, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Reassembly information: paso 31, imagen 3 de 3
    • During reassembly, the next two steps demonstrate how to replace the flip battery and bottom interconnect cable conductive tape.
    • Peel off the new conductive tape from its liner and apply the sticky side to the bottom interconnect connector, making sure to bridge the logic board.
    Pregunta a FixBot
    Agregar Comentario
  32. Google Pixel Fold Base Battery Replacement: paso 32, imagen 1 de 3 Google Pixel Fold Base Battery Replacement: paso 32, imagen 2 de 3 Google Pixel Fold Base Battery Replacement: paso 32, imagen 3 de 3
    • Use a spudger, or your fingers, to press down the conductive tape and adhere it.
    • Use tweezers, or your fingers, to pull on the tab and expose the tape.
    Pregunta a FixBot
    Agregar Comentario
  33. Google Pixel Fold Base Battery Replacement, Disconnect the ultra wideband antenna: paso 33, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Disconnect the ultra wideband antenna: paso 33, imagen 2 de 2
    • If your graphite sheet is taped out of the way, remove the tape now.
    • Use the point of a spudger to pry up and disconnect the ultra wideband antenna press connector.
    Pregunta a FixBot
    Agregar Comentario
  34. Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 34, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 34, imagen 2 de 2
    • The ultra wideband antenna is lightly adhered to the graphite sheet.
    • Slide an opening pick under the antenna to separate its adhesive.
    Pregunta a FixBot
    Agregar Comentario
  35. Google Pixel Fold Base Battery Replacement, Remove the ultra wideband antenna: paso 35, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Remove the ultra wideband antenna: paso 35, imagen 2 de 2
    Tesa 61395 Tape
    $8.95
    • Peel up the ultra wideband antenna and remove it.
    • During reassembly, if your adhesive is still sticky and intact, you can reuse it. Otherwise, follow this guide to replace it.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the antenna to the logic board.
    Pregunta a FixBot
    Agregar Comentario
  36. Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 36, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 36, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 36, imagen 3 de 3
    • Slide an opening pick under the top of the graphite sheet to separate the thermal insulator adhesive.
    Pregunta a FixBot
    Agregar Comentario
  37. Google Pixel Fold Base Battery Replacement, Remove the graphite sheet: paso 37, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Remove the graphite sheet: paso 37, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Remove the graphite sheet: paso 37, imagen 3 de 3
    • Peel the graphite sheet off the logic board to separate the remaining adhesive.
    • Remove the graphite sheet.
    Pregunta a FixBot
    Agregar Comentario
  38. Google Pixel Fold Base Battery Replacement: paso 38, imagen 1 de 1
    • If there's any remaining adhesive, use tweezers to peel it off the logic board.
    Pregunta a FixBot
    Agregar Comentario
  39. Google Pixel Fold Base Battery Replacement, Remove the bottom speaker: paso 39, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Remove the bottom speaker: paso 39, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Remove the bottom speaker: paso 39, imagen 3 de 3
    Tesa 61395 Tape
    $8.95
    • Don't pry against the battery with the spudger, as you risk damaging it.
    • Insert the flat end of a spudger between the battery and the bottom speaker.
    • Twist the spudger to separate the adhesive securing the bottom speaker.
    • Remove the bottom speaker.
    • During reassembly, if your adhesive is still intact and sticky, you can reuse it. Otherwise, follow this guide to replace the adhesive.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the speaker to the frame.
    Pregunta a FixBot
    Agregar Comentario
  40. Google Pixel Fold Base Battery Replacement, Disconnect the fingerprint sensor: paso 40, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Disconnect the fingerprint sensor: paso 40, imagen 2 de 2
    • Be careful during this step, as you risk breaking the small surface-mounted components on the logic board. Avoid prying against the logic board.
    • Use the point of a spudger to lift up and disconnect the fingerprint sensor press connector.
    Pregunta a FixBot
    Agregar Comentario
  41. Google Pixel Fold Base Battery Replacement, Remove the tape: paso 41, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Remove the tape: paso 41, imagen 2 de 2
    • Peel off the tape covering the top interconnect cable.
    Pregunta a FixBot
    Agregar Comentario
  42. Google Pixel Fold Base Battery Replacement, Reassembly information: paso 42, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Reassembly information: paso 42, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Reassembly information: paso 42, imagen 3 de 3
    • During reassembly, perform the following to replace the conductive tape:
    • Peel off the new conductive tape from its liner and apply the sticky side to the press connector, making sure to bridge the logic board.
    Pregunta a FixBot
    Agregar Comentario
  43. Google Pixel Fold Base Battery Replacement, Unfasten the top interconnect cable: paso 43, imagen 1 de 1
    • Use a Torx Plus 3IP driver to remove the two screws securing the top interconnect cable:
    • One 2.8 mm‑long screw
    • One 2.5 mm‑long screw
    Pregunta a FixBot
    Agregar Comentario
  44. Google Pixel Fold Base Battery Replacement, Disconnect the top interconnect cable: paso 44, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Disconnect the top interconnect cable: paso 44, imagen 2 de 2
    • The metal bracket securing the connector is part of the press connector itself. Don’t try to remove the bracket from the connector.
    • Use the point of a spudger to pry up and disconnect the top interconnect cable press connector.
    Pregunta a FixBot
    Agregar Comentario
  45. Google Pixel Fold Base Battery Replacement, Disconnect the inner screen: paso 45, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Disconnect the inner screen: paso 45, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Disconnect the inner screen: paso 45, imagen 3 de 3
    • Use the flat end of a spudger to lift up and disconnect the inner screen press connector.
    • Move the inner screen cable up 90° over the right edge of the phone before continuing.
    Pregunta a FixBot
    Agregar Comentario
  46. Google Pixel Fold Base Battery Replacement, Unfasten the top bracket: paso 46, imagen 1 de 1
    Pregunta a FixBot
    Agregar Comentario
  47. Google Pixel Fold Base Battery Replacement, Remove the top bracket: paso 47, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Remove the top bracket: paso 47, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Remove the top bracket: paso 47, imagen 3 de 3
    • Pull the top bracket toward the left edge of the phone to release its clips.
    • Remove the top bracket.
    • During reassembly, insert the top bracket clips under their slots in the frame before aligning the screw holes.
    Pregunta a FixBot
    Agregar Comentario
  48. Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 48, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 48, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 48, imagen 3 de 3
    Tesa 61395 Tape
    $8.95
    • The 5G mmWave antenna is lightly adhered to the frame.
    • Insert the point of a spudger between the frame and the right edge of the 5G mmWave antenna.
    • Pry up to separate the adhesive.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the antenna to the frame.
    Pregunta a FixBot
    Agregar Comentario
  49. Google Pixel Fold Base Battery Replacement, Disconnect the front camera: paso 49, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Disconnect the front camera: paso 49, imagen 2 de 2
    • Insert the point of a spudger under the bottom right corner of the front camera press connector.
    • Don't insert the spudger anywhere else, as you risk breaking surface-mounted components on the logic board.
    • Pry up and disconnect the front camera press connector.
    Pregunta a FixBot
    Agregar Comentario
  50. Google Pixel Fold Base Battery Replacement, Heat the front camera: paso 50, imagen 1 de 1
    • The front camera is adhered to the frame.
    • Heat an iOpener and apply it to the front camera for two minutes.
    • You can also use a hair dryer or heat gun, but be careful not to overheat the phone. Don't concentrate the heat on a single spot.
    Pregunta a FixBot
    Agregar Comentario
  51. Google Pixel Fold Base Battery Replacement, Remove the front camera: paso 51, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Remove the front camera: paso 51, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Remove the front camera: paso 51, imagen 3 de 3
    Tesa 61395 Tape
    $8.95
    • Use tweezers to grab the front camera by its connector, as close to the camera body as possible.
    • Don't pinch the press connector's pins, as you may bend them.
    • Pull straight up to separate the adhesive and remove the front camera.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the front camera to the frame.
    Pregunta a FixBot
    Agregar Comentario
  52. Google Pixel Fold Base Battery Replacement, Unfasten the logic board: paso 52, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Unfasten the logic board: paso 52, imagen 2 de 2
    • Use a Torx Plus 3IP driver to remove the two screws securing the logic board:
    • One 2.8 mm‑long screw near the top left corner
    • One 2.5 mm‑long screw near bottom right corner
    Pregunta a FixBot
    Agregar Comentario
  53. Google Pixel Fold Base Battery Replacement, Tape the cables: paso 53, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Tape the cables: paso 53, imagen 2 de 2
    • Use tape with light adhesive, such as painter's tape, to keep the three cables out of the way before continuing:
    • Fingerprint sensor cable
    • Top interconnect cable
    • Inner screen cable
    • Don't fold the cables at a sharp angle, as you can crease the cable.
    Pregunta a FixBot
    Agregar Comentario
  54. Google Pixel Fold Base Battery Replacement, Release the logic board: paso 54, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Release the logic board: paso 54, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Release the logic board: paso 54, imagen 3 de 3
    • Insert the flat end of a spudger under the top of the logic board, near the front camera recess.
    • Pry up to release the logic board from its upper alignment peg.
    Pregunta a FixBot
    Agregar Comentario
  55. Google Pixel Fold Base Battery Replacement, Remove the logic board: paso 55, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Remove the logic board: paso 55, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Remove the logic board: paso 55, imagen 3 de 3
    • Be very careful during this step, as the logic board is fragile and has many cutouts in the frame. Go slowly, and don’t yank the logic board if it feels stuck.
    • Grip the top of the logic board with your fingers.
    • Lift the logic board upward while pulling it gently toward the right edge of the phone to release the bottom clip.
    • You'll feel some resistance from the white logic board bracket. Lift slowly until it clears its slot in the frame.
    • You'll also feel some resistance from the thermal paste bonding the logic board to the frame.
    • Once the clip is released, lift straight up to remove the logic board from its lower alignment peg.
    • Remove the logic board.
    Pregunta a FixBot
    Agregar Comentario
  56. Google Pixel Fold Base Battery Replacement, Reassembly information: paso 56, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Reassembly information: paso 56, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Reassembly information: paso 56, imagen 3 de 3
    • During reassembly, perform the following to clean the thermal paste:
    • Use the flat end of a spudger to scrape off the thermal paste on the bottom of the logic board.
    • Clean any remaining thermal paste residue with isopropyl alcohol (>90%) and either a coffee filter or a lint-free cloth.
    • Repeat the cleaning process for the thermal paste on the frame.
    • During reassembly, follow this guide to reapply thermal paste to your device.
    • When applying new thermal paste, use the flat end of a spudger to spread it evenly across the logic board. Try to match the original spread.
    Pregunta a FixBot
    Agregar Comentario
  57. Google Pixel Fold Base Battery Replacement: paso 57, imagen 1 de 3 Google Pixel Fold Base Battery Replacement: paso 57, imagen 2 de 3 Google Pixel Fold Base Battery Replacement: paso 57, imagen 3 de 3
    • The next four steps will demonstrate how to reinstall the logic board.
    • Insert the USB-C port into its cutout in the frame at a shallow angle.
    • Use your finger to press the USB-C port down until the orange rubber gasket is level with its cutout—not twisted or pinched.
    • Press the bottom of the logic board over its lower alignment peg and engage its spring connectors.
    Pregunta a FixBot
    Agregar Comentario
  58. Google Pixel Fold Base Battery Replacement: paso 58, imagen 1 de 3 Google Pixel Fold Base Battery Replacement: paso 58, imagen 2 de 3 Google Pixel Fold Base Battery Replacement: paso 58, imagen 3 de 3
    • While pushing the logic board toward the bottom edge of the phone, press the logic board into its lower metal clip.
    Pregunta a FixBot
    Agregar Comentario
  59. Google Pixel Fold Base Battery Replacement: paso 59, imagen 1 de 2 Google Pixel Fold Base Battery Replacement: paso 59, imagen 2 de 2
    • Press down on the white logic board bracket so it rests under the lip in the frame's edge.
    Pregunta a FixBot
    Agregar Comentario
  60. Google Pixel Fold Base Battery Replacement: paso 60, imagen 1 de 3 Google Pixel Fold Base Battery Replacement: paso 60, imagen 2 de 3 Google Pixel Fold Base Battery Replacement: paso 60, imagen 3 de 3
    • Make sure all of the cables are above the logic board before securing it back into the frame. If you haven't taped them, do so now to avoid trapping them as you work.
    • While pressing down on the white logic board bracket, push the logic board against the left edge of the phone.
    • Position the logic board over the upper alignment peg.
    • Press down to secure the logic board.
    Pregunta a FixBot
    Agregar Comentario
  61. Google Pixel Fold Base Battery Replacement, Reposition the cable: paso 61, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Reposition the cable: paso 61, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Reposition the cable: paso 61, imagen 3 de 3
    • Move the flip battery and bottom interconnect cable away from the battery.
    • Be careful to not crease the cable. Give the cable some slack to avoid straining it.
    • Use tape with light adhesive, like painter's tape, to secure the cable to the side of the phone.
    Pregunta a FixBot
    Agregar Comentario
  62. Google Pixel Fold Base Battery Replacement, Separate the battery pull tabs: paso 62, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Separate the battery pull tabs: paso 62, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Separate the battery pull tabs: paso 62, imagen 3 de 3
    • Take care not to puncture or bend the battery with sharp tools—it can leak dangerous chemicals and/or catch fire.
    • Use a pair of blunt nose tweezers, or your fingers, to peel the clear plastic pull tabs away from the battery.
    Pregunta a FixBot
    Agregar Comentario
  63. Google Pixel Fold Base Battery Replacement, Heat the battery adhesive: paso 63, imagen 1 de 1
    • Unfold the phone and flip it over.
    • Heat an iOpener and apply it the section of the inner screen above the base battery for two minutes.
    Pregunta a FixBot
    Agregar Comentario
  64. Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 64, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 64, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Separate the adhesive: paso 64, imagen 3 de 3
    • The battery adhesive is extremely strong. Be careful when pulling on the battery and reapply heat if necessary to avoid bending the battery.
    • Close your phone.
    • Grip the ends of the plastic pull tabs with your fingers.
    • Pull straight up with constant, steady force to separate the adhesive under the battery. Work slowly and let time do the work for you until the adhesive separates.
    • If you're having trouble separating the adhesive, apply more heat and try again.
    • If you're having a lot of trouble separating the adhesive, or if you feel like you might damage the battery, follow the next five steps for an alternate method. If you were successful, jump to this step.
    Pregunta a FixBot
    Agregar Comentario
  65. Google Pixel Fold Base Battery Replacement, Apply isopropyl alcohol: paso 65, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Apply isopropyl alcohol: paso 65, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Apply isopropyl alcohol: paso 65, imagen 3 de 3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire. In case you're struggling to pull up the battery, apply more isopropyl alcohol and try again.
    • Apply a few drops of high concentration (>90%) isopropyl alcohol in the gap between the frame and the left edge of the battery.
    Pregunta a FixBot
    Agregar Comentario
  66. Google Pixel Fold Base Battery Replacement, Tilt the phone: paso 66, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Tilt the phone: paso 66, imagen 2 de 2
    • Tilt the left side of the phone up to let the isopropyl alcohol flow under the battery.
    • Wait one minute for the alcohol to soften the adhesive.
    Pregunta a FixBot
    Agregar Comentario
  67. Google Pixel Fold Base Battery Replacement, Insert an opening pick: paso 67, imagen 1 de 3 Google Pixel Fold Base Battery Replacement, Insert an opening pick: paso 67, imagen 2 de 3 Google Pixel Fold Base Battery Replacement, Insert an opening pick: paso 67, imagen 3 de 3
    • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Apply a suction cup to the battery, as close to the center of the left edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the battery and the frame.
    Pregunta a FixBot
    Agregar Comentario
  68. Google Pixel Fold Base Battery Replacement, Rotate the pick: paso 68, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Rotate the pick: paso 68, imagen 2 de 2
    • Rotate the opening pick so its long edge sits in the gap.
    Pregunta a FixBot
    Agregar Comentario
  69. Google Pixel Fold Base Battery Replacement, Pry up the battery: paso 69, imagen 1 de 2 Google Pixel Fold Base Battery Replacement, Pry up the battery: paso 69, imagen 2 de 2
    • Pull up on the suction cup with strong, steady force while also prying up with the opening pick to separate the battery from the frame.
    • If you're feeling a lot of resistance, apply a few more drops of isopropyl alcohol and try again.
    • Depending on the condition of your adhesive, you might need to repeat the alcohol and prying cycle a few times before the battery adhesive yields.
    Pregunta a FixBot
    Agregar Comentario
  70. Google Pixel Fold Base Battery Replacement, Remove the battery: paso 70, imagen 1 de 1
    Tesa 61395 Tape
    $8.95
    • Lift the battery out its recess and remove it.
    • During reassembly, if your adhesive is still intact and sticky, then you can reuse it. Otherwise, follow this guide to replace the adhesive with custom cut strips.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the battery to the frame.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
241,315 Reputación
1,180 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 122
27,498 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 126
Todo El Tiempo: 3,025
