Introducción
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken, cracked, or unresponsive screen on your Google Pixel 9 Pro XL.
If your screen doesn't come with adhesive pre‑installed, you'll need replacement screen adhesive in order to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the adhesive.
Qué necesitas
Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
Use a hair dryer, heat gun, or hot plate to heat the entire screen until it's almost too hot to touch.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
Insert the tip of an opening pick under the screen.
Slide the opening pick along the top edge to separate the adhesive securing it.
Flip the screen over the right edge of your phone and prop it up with the suction handle.
Use angled tweezers to pry up the top edge of the screen cable bracket.
Remove the bracket.
Insert the point of a spudger under the left edge of the screen cable press connector and pry up to disconnect it.
Remove the screen.
When handling your screen, grip it by its edges.
When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
Use a spudger to scrape up and remove all the old screen adhesive from the perimeter of the frame.
Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
Allow the frame to dry completely before continuing.
Before applying the adhesive, make sure you know its proper orientation on the frame. Hold the adhesive over your phone to find its proper alignment.
The adhesive has a corresponding groove on the perimeter of the frame.
Cutouts in the blue liner correspond to spring contacts on the frame.
Peel down the top half of the larger, clear liner to expose the adhesive—don't remove the whole liner yet.
Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
Carefully lay your replacement screen display‑side‑down just to the right of your phone so you can reconnect the cable.
Align the screen press connector over its socket and gently press down on one side until it clicks into place, then press down on the other side.
Hook the bottom edge of the screen cable bracket into its cutout and firmly press down on the top edge until the bracket clicks into place.
Leave the perimeter display adhesive liners in place for now.
Thoroughly check your replacement screen for any small plastic liners (specifically near the front facing camera and screen cable) and use your fingers to remove them—you can identify the liners by their plastic pull tabs.
Use tweezers or your fingers to remove the two remaining blue liners from the underside of the screen.
Skip the next step.
Congratulations on completing your screen repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
10 personas más completaron esta guía.
6Guía Comentarios
do we need to do calibrate the screen or UDFPS PUnder Display FingerPrint Sensor) for this google pixel 9 pro xl after the screen replacement ?
Hi David! You don't need to calibrate the UDFPS for the Pixel 9 series phones. When powering the phone on for the first time after your repair, make sure the phone is laying flat and nothing is touching the screen. I've added a note about this is the guides. Thank you!
Thanks for the guide replaced my brother's screen with the one I bought from you guys!
the quide was clear and helpful but there is one contredidction with it at step 22 it said to test ther device. but later at the end it says during first boot not to touch the device.
beside that the guide and tools provided are amazing
That's a great point! Thanks for the comment, we've updated the guide accordingly.
