Introducción
Use this guide to replace a worn-out or dead battery in your Fitbit Ionic.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your Fitbit Ionic. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Before starting, take your Fitbit Ionic off the charger and power it down.
Heat an iOpener and apply it on the display for at least two minutes to soften the adhesive underneath.
Use the flat end of a spudger to loosen and pry up the mildly glued NFC antenna.
Carefully fold the NFC antenna in the direction of the upper edge of the watch.
To reassemble your Fitbit ionic follow these instructions in reverse.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 personas más completaron esta guía.
14 comentarios
This guide is very detailed and pretty accurate. Thank you for posting it!
Does anyone know how crucial the ‘Calibration’ procedure noted at the end article is?
I replaced my battery and it drains so quickly - during the course of a few hours.
But I didn’t try leaving it on the charger for 2 hours after 100% is reached. Trying that now.
