Saltar al contenido principal
Fitbit Charge 2 Battery Replacement
Qué necesitas
  1. Fitbit Charge 2 Battery Replacement, Remove the watch band: paso 1, imagen 1 de 1
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. Fitbit Charge 2 Battery Replacement, Heat the touch screen: paso 2, imagen 1 de 1
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assemly.
  3. Fitbit Charge 2 Battery Replacement, Slide along the left edge: paso 3, imagen 1 de 3 Fitbit Charge 2 Battery Replacement, Slide along the left edge: paso 3, imagen 2 de 3 Fitbit Charge 2 Battery Replacement, Slide along the left edge: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    iSesamo Opening Tool
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. Fitbit Charge 2 Battery Replacement, Slide along the bottom edge: paso 4, imagen 1 de 2 Fitbit Charge 2 Battery Replacement, Slide along the bottom edge: paso 4, imagen 2 de 2
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. Fitbit Charge 2 Battery Replacement: paso 5, imagen 1 de 3 Fitbit Charge 2 Battery Replacement: paso 5, imagen 2 de 3 Fitbit Charge 2 Battery Replacement: paso 5, imagen 3 de 3
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. Fitbit Charge 2 Battery Replacement: paso 6, imagen 1 de 2 Fitbit Charge 2 Battery Replacement: paso 6, imagen 2 de 2
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. Fitbit Charge 2 Battery Replacement: paso 7, imagen 1 de 2 Fitbit Charge 2 Battery Replacement: paso 7, imagen 2 de 2
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. Fitbit Charge 2 Battery Replacement: paso 8, imagen 1 de 2 Fitbit Charge 2 Battery Replacement: paso 8, imagen 2 de 2
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. Fitbit Charge 2 Battery Replacement: paso 9, imagen 1 de 2 Fitbit Charge 2 Battery Replacement: paso 9, imagen 2 de 2
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. Fitbit Charge 2 Battery Replacement: paso 10, imagen 1 de 1
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
  11. Fitbit Charge 2 Battery Replacement, Remove the protecting sticker: paso 11, imagen 1 de 2 Fitbit Charge 2 Battery Replacement, Remove the protecting sticker: paso 11, imagen 2 de 2
    • Use a pair of blunt nosed tweezers to remove the black sticker which covering the touch screen connector.
  12. Fitbit Charge 2 Battery Replacement, Open the ZIF connector: paso 12, imagen 1 de 2 Fitbit Charge 2 Battery Replacement, Open the ZIF connector: paso 12, imagen 2 de 2
    • Use the pointed end of a spudger to open the ZIF connector by pushing up the black flap.
  13. Fitbit Charge 2 Battery Replacement, Remove the touch screen assembly: paso 13, imagen 1 de 3 Fitbit Charge 2 Battery Replacement, Remove the touch screen assembly: paso 13, imagen 2 de 3 Fitbit Charge 2 Battery Replacement, Remove the touch screen assembly: paso 13, imagen 3 de 3
    • Pull the touch screen flex cable straight out its socket.
    • Remove the touch screen assembly.
  14. Fitbit Charge 2 Battery Replacement, Unfasten the screws: paso 14, imagen 1 de 1
    • Remove the two Phillips screws securing the motherboard cover:
    • One 2.5 mm screw
    • One 2.8 mm screw
  15. Fitbit Charge 2 Battery Replacement, Remove the motherboard shield: paso 15, imagen 1 de 2 Fitbit Charge 2 Battery Replacement, Remove the motherboard shield: paso 15, imagen 2 de 2
    • Use a pair of blunt nose tweezers to remove the motherboard shield.
  16. Fitbit Charge 2 Battery Replacement, Disconnect the heart rate monitor sensor: paso 16, imagen 1 de 2 Fitbit Charge 2 Battery Replacement, Disconnect the heart rate monitor sensor: paso 16, imagen 2 de 2
    • Use the pointed end of a spudger to pry up and disconnect the heart rate monitor sensor flex cable.
  17. Fitbit Charge 2 Battery Replacement, Remove the motherboard: paso 17, imagen 1 de 3 Fitbit Charge 2 Battery Replacement, Remove the motherboard: paso 17, imagen 2 de 3 Fitbit Charge 2 Battery Replacement, Remove the motherboard: paso 17, imagen 3 de 3
    • Use an opening pick to pry up and remove the motherboard which is holding the battery.
  18. Fitbit Charge 2 Battery Replacement, Separate the battery from the motherboard: paso 18, imagen 1 de 3 Fitbit Charge 2 Battery Replacement, Separate the battery from the motherboard: paso 18, imagen 2 de 3 Fitbit Charge 2 Battery Replacement, Separate the battery from the motherboard: paso 18, imagen 3 de 3
    • The battery is mildly glued to the motherboard.
    • Slide an opening pick underneath the battery to cut the adhesive.
    • Don't try to remove the battery all the way yet! It's still connected to the motherboard.
  19. Fitbit Charge 2 Battery Replacement: paso 19, imagen 1 de 1
    • The next steps require desoldering the two battery cables from the motherboard.
    • Use this picture as reference for resoldering during re-assembly or make your own photo if the cable order differs in your model.
  20. Fitbit Charge 2 Battery Replacement: paso 20, imagen 1 de 3 Fitbit Charge 2 Battery Replacement: paso 20, imagen 2 de 3 Fitbit Charge 2 Battery Replacement: paso 20, imagen 3 de 3
    • Use a soldering iron to desolder the first battery cable from the motherboard.
  21. Fitbit Charge 2 Battery Replacement: paso 21, imagen 1 de 2 Fitbit Charge 2 Battery Replacement: paso 21, imagen 2 de 2
    • Use a soldering iron to desolder the second battery cable from the motherboard.
  22. Fitbit Charge 2 Battery Replacement: paso 22, imagen 1 de 1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • Make sure the battery cables are long enough to solder them onto the motherboard before installing new adhesive to the battery.
Conclusión
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
9 personas más completaron esta guía.
Adriana Zwink
Miembro Desde 12/18/19
56,234 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,445 Guías creadas
4 comentarios
Donde se compran los repuestos?
Leonardo - Contestar
Muy buenas las instrucciones! Donde puedo comprar los repuestos y herramientas? Gracias!!!
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 18
Ultimos 7 días: 113
Ultimos 30 días: 486
Todo El Tiempo: 26,389
