Introducción
Follow this guide to replace the motherboard in your Sony DualSense controller. Replacing the motherboard is necessary to resolve joystick drift and charging port failure. Make sure to purchase a motherboard that includes joysticks calibrated at the factory.
Note: This guide is for current DualSense controllers with FCC IDs that end with A. Check the back of your controller to verify your model. If yours ends in a 1, it is an early model and there will be internal differences. Follow these guides for the earlier version.
Qué necesitas
Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
Lift the middle trim over the joysticks to remove it.
Insert the flat end of your spudger into the gap above the L1 button.
Pry the spudger upward to remove the L1 button.
Insert the flat end of your spudger into the gap above the R1 button.
Pry the spudger upward to remove the R1 button.
Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
Use your hands to carefully pull the rear case off of the controller.
Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
Use the pointed end of your spudger to remove the lower microphone from its bracket next to the battery.
Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
Don't completely remove the ribbon cable yet.
Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
Carefully guide the joysticks through the front case and lift the motherboard out.
Flip the motherboard and midframe over to access the red and black vibration motor wires.
Use a soldering iron to disconnect the vibration motor wires from the motherboard.
Use your fingers to remove the left and right joystick covers from the motherboard.
Use your fingers to remove the speaker and foam pad from the motherboard.
4 personas más completaron esta guía.
Un comentario
"Replacing the motherboard is necessary to resolve joystick drift and charging port failure." Cleaning the joysticks out with compressed air and/or rubbing alcohol can often resolve the drift issue until it needs to be cleaned again. Joystick replacement is an option without total board replacement. Controllers possibly to calibrate at startup and can be reset to calibrate as well https://osgamers.com/frequently-asked-qu...
Charge port failure definitely doesn't require a board replacement. It's the pins are small, but should be manageable with flux.
