Saltar al contenido principal
Dell XPS 17 9710 SSD Replacement
Qué necesitas
  1. Dell XPS 17 9710 SSD Replacement, Prepare your device: paso 1, imagen 1 de 1
    • For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the replacement. If your battery is swollen, take appropriate precautions.
    • Power off and unplug your laptop.
    • Close the display and flip the entire laptop upside-down, with the hinge facing away from you.
  2. Dell XPS 17 9710 SSD Replacement, Remove the lower case screws: paso 2, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the eight 4.4 mm-long screws that secure the lower case.
    • The lower case is further secured by various clips that must be released before removal.
  3. Dell XPS 17 9710 SSD Replacement, Begin to release the clips: paso 3, imagen 1 de 3 Dell XPS 17 9710 SSD Replacement, Begin to release the clips: paso 3, imagen 2 de 3 Dell XPS 17 9710 SSD Replacement, Begin to release the clips: paso 3, imagen 3 de 3
    • Insert an opening pick at the bottom left corner, between the lower case and the chassis.
    • Insert the flat end of a spudger into the gap created by the opening pick.
    • Pivot the spudger up to release the first set of retaining clips.
    • Repeat this process for the bottom right corner.
  4. Dell XPS 17 9710 SSD Replacement, Release the remaining clips: paso 4, imagen 1 de 3 Dell XPS 17 9710 SSD Replacement, Release the remaining clips: paso 4, imagen 2 de 3 Dell XPS 17 9710 SSD Replacement, Release the remaining clips: paso 4, imagen 3 de 3
    • Insert an opening pick into the gap created on the front edge of the laptop.
    • Slide the opening pick around the entire perimeter of the laptop, prying up intermittently, until the lower case fully releases from the clips on the chassis.
  5. Dell XPS 17 9710 SSD Replacement, Remove the lower case: paso 5, imagen 1 de 3 Dell XPS 17 9710 SSD Replacement, Remove the lower case: paso 5, imagen 2 de 3 Dell XPS 17 9710 SSD Replacement, Remove the lower case: paso 5, imagen 3 de 3
    • The lip of the lower case is very sharp. Handle it with care, and try not to slide your fingers along any of the edges.
    • Lift the lower case up and off of the chassis to remove it.
  6. Dell XPS 17 9710 SSD Replacement, Battery: paso 6, imagen 1 de 1
    • Remove the seven 4.1 mm-long Phillips screws that secure the battery.
  7. Dell XPS 17 9710 SSD Replacement, Remove the battery: paso 7, imagen 1 de 3 Dell XPS 17 9710 SSD Replacement, Remove the battery: paso 7, imagen 2 de 3 Dell XPS 17 9710 SSD Replacement, Remove the battery: paso 7, imagen 3 de 3
    • Use the flat end of a spudger to lift the front edge of the battery until you can easily grip it with your fingers.
    • Whenever you use a spudger or other sharp tools near the battery, be very careful not to accidentally poke or puncture it.
    • Lift the battery up and out of its recess to remove it.
  8. Dell XPS 17 9710 SSD Replacement, SSD: paso 8, imagen 1 de 1
    • Remove the single 4.1 mm Phillips screw that secures the left side of the left SSD cover.
    • The screw securing the right side of the SSD cover was removed during the battery removal procedure.
  9. Dell XPS 17 9710 SSD Replacement: paso 9, imagen 1 de 3 Dell XPS 17 9710 SSD Replacement: paso 9, imagen 2 de 3 Dell XPS 17 9710 SSD Replacement: paso 9, imagen 3 de 3
    • Remove the SSD cover.
    • With the SSD cover removed, the SSD will pop up at a shallow angle.
  10. Dell XPS 17 9710 SSD Replacement: paso 10, imagen 1 de 3 Dell XPS 17 9710 SSD Replacement: paso 10, imagen 2 de 3 Dell XPS 17 9710 SSD Replacement: paso 10, imagen 3 de 3
    • Grip the free end of the SSD and pull it away from the socket to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD cover and screw.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Una persona más ha completado esta guía.
Connor
Miembro Desde 03/29/22
12,295 Reputación
64 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 119
19,523 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 11
Ultimos 30 días: 24
Todo El Tiempo: 474
