Saltar al contenido principal
Dell XPS 15 9530 Motherboard Replacement
Qué necesitas
  1. Dell XPS 15 9530 Motherboard Replacement, Fan: paso 1, imagen 1 de 3 Dell XPS 15 9530 Motherboard Replacement, Fan: paso 1, imagen 2 de 3 Dell XPS 15 9530 Motherboard Replacement, Fan: paso 1, imagen 3 de 3
    • Turn the laptop upside down.
    • Unscrew ten 3 mm screws on the back cover with a Torx T5 screwdriver.
    • Remove two more 3 mm screws with a Phillips #0 screwdriver.
  2. Dell XPS 15 9530 Motherboard Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9530 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the three screws on each fan.
  3. Dell XPS 15 9530 Motherboard Replacement: paso 3, imagen 1 de 2 Dell XPS 15 9530 Motherboard Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use metal tweezers to carefully unplug the fan cables from the motherboard.
  4. Dell XPS 15 9530 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the fans by gently lifting up the edges until the fans disconnect from the motherboard completely.
  5. Dell XPS 15 9530 Motherboard Replacement, Battery: paso 5, imagen 1 de 2 Dell XPS 15 9530 Motherboard Replacement, Battery: paso 5, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  6. Dell XPS 15 9530 Motherboard Replacement: paso 6, imagen 1 de 1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  7. Dell XPS 15 9530 Motherboard Replacement: paso 7, imagen 1 de 1
    • Lift the battery off the chassis.
  8. Dell XPS 15 9530 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 3 Dell XPS 15 9530 Motherboard Replacement, Motherboard: paso 8, imagen 2 de 3 Dell XPS 15 9530 Motherboard Replacement, Motherboard: paso 8, imagen 3 de 3
    • Using both hands and plastic tweezers, disconnect the cables from the laptop base.
  9. Dell XPS 15 9530 Motherboard Replacement: paso 9, imagen 1 de 2 Dell XPS 15 9530 Motherboard Replacement: paso 9, imagen 2 de 2
    • Use phillips #0 screwdriver to unscrew the screws connecting the motherboard and the laptop base.
    • Lift up the motherboard with the plastic fan holder on top of it.
  10. Dell XPS 15 9530 Motherboard Replacement: paso 10, imagen 1 de 3 Dell XPS 15 9530 Motherboard Replacement: paso 10, imagen 2 de 3 Dell XPS 15 9530 Motherboard Replacement: paso 10, imagen 3 de 3
    • Use T5 Torx screwdriver to unscrew the screws connecting the plastic fan holder and the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 2,233
