Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Bike Chain Installation
Qué necesitas
  1. Bike Chain Installation, Bike Chain Installation: paso 1, imagen 1 de 2 Bike Chain Installation, Bike Chain Installation: paso 1, imagen 2 de 2
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
    Pregunta a FixBot
    Agregar Comentario
  2. Bike Chain Installation: paso 2, imagen 1 de 2 Bike Chain Installation: paso 2, imagen 2 de 2
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
    Pregunta a FixBot
    Agregar Comentario
Linea de Meta
3 personas más completaron esta guía.
aaron thielk
Miembro Desde 10/10/10
1,984 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-13, Maness Fall 2010 Miembro de Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
Miembros de 4
21 Guías creadas
2Guía Comentarios
How To Connect A Bicycle Chain
https://www.youtube.com/watch?v=d_PntKQ8...
jack bar - Contestar Compartir
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 27
Ultimos 30 días: 118
Todo El Tiempo: 17,491
