Introducción
This guide shows the reader how to disassemble the Apple Cinema Display M8149 so that the screen can be replaced. The tools required for this section are the spudger and the PH 2 screwdriver.
Herramientas
Partes
No se especificaron partes.
Flip the Cinema Display so it is on its face and the feet are pointed away from you.
Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
Locate and carefully remove the two tape plugs on either side of the control board using the spudger.
Turn your attention to the left side of the cinema display.
Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
Remove the circuit board by gently lifting it from the display.
Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting.
3 personas más completaron esta guía.
