Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 3
Unscrew the four screws (4.79x2.33mm) on the metal box using the PH 2 screwdriver. Lift away the metal cover to reveal a circuit board with you hand. Unscrew the two terminal screws (4.79x2.34mm) using the PH 2 screwdriver.
  • Unscrew the four screws (4.79x2.33mm) on the metal box using the PH 2 screwdriver.
  • Lift away the metal cover to reveal a circuit board with you hand.
  • Unscrew the two terminal screws (4.79x2.34mm) using the PH 2 screwdriver.
Insertar traducción aquí
