Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury. Flip the Cinema Display so it is on its face and the feet are pointed away from you. Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
  • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
  • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
  • Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
  • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
Insertar traducción aquí
