Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Turn your attention to the left side of the cinema display. Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board. Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
  • Turn your attention to the left side of the cinema display.
  • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
  • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
  • Remove the circuit board by gently lifting it from the display.
Insertar traducción aquí
