Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
AlphaSmart Pro Front Panel Replacement
Qué necesitas
  1. AlphaSmart Pro Front Panel Replacement, Separating Panels: paso 1, imagen 1 de 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: paso 1, imagen 2 de 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: paso 1, imagen 3 de 3
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
    Pregunta a FixBot
    Agregar Comentario
  2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: paso 2, imagen 1 de 2 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: paso 2, imagen 2 de 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • You are now able to separate the front panel from the back panel.
    Pregunta a FixBot
    Agregar Comentario
  3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: paso 3, imagen 1 de 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: paso 3, imagen 2 de 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: paso 3, imagen 3 de 3
    • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
    • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Equipo
Clemson, Team 1-1, Benson Fall 2014 Miembro de Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
Miembros de 4
16 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 585
