Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
To remove the ribbon cable, use the spudger to lift each side of the connector from the socket. Gently pull up on the connector to completely remove the connector from the socket.
Detaching Ribbon Cable
  • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
  • Gently pull up on the connector to completely remove the connector from the socket.
  • You are now able to separate the front panel from the back panel.
Insertar traducción aquí
