Estudiante en Progreso
Este wiki está siendo editado por estudiantes diligentes.
V-Moda Crossfade II Wireless Does not power on
The issue could be as simple as the V-Moda Crossfade II Wireless being turned off. Turn on the V-Moda Crossfade II Wireless by pressing the power button.
Software Glitch or Error
The issue could be as simple as a software issue on the V-Moda Crossfade II Wireless. Hold the + and - buttons on the V-Moda Crossfade II Wireless to reset it.
External charging issue
The most common reason for the issue is the charging brick, charging cable, or wall socket used are faulty or broken.
- Change the charging cable to see if it is the problem.
- Change the wall socket used.
- Change the charging brick used.
Broken or clogged charging port
The problem could be the charging port getting damaged, being dirty, or having something stuck.
- Clean the charging port using compressed air,or q-tips with alcohol.
- Unclog the foreign object from he charging port
- Replace the charging port. See our [Replacement guide for charging port].
Degraded or dead battery
Another common issue with the V-Moda Crossfade II Wireless is the battery going bad or dying. Replace the dead battery with a new one. See our [Replacement guide for battery].
Internal Wiring Issue
Internal wiring within the V-Moda Crossfade II Wireless could be disconnected or damaged.
- Reconnect the wiring.
- Solder the wiring back to its correct position.
- Replace the damaged wiring. See our[Replacement guide for faulty wiring].
Degraded or dead Motherboard
Another cause of the V-Moda Crossfade II Wireless not powering on could be a faulty motherboard. The motherboard could have short circuited or have a solder that disconnected.
- Solder the disconnected portion of the motherboard.
- Replace the motherboard .See our[ Replacement guide for motherboard]
Blown out speakers
The issue could be that the volume on the V-Moda Crossfade II Wireless is turned down to zero or the speakers died.
- Turn the volume up on the V-Moda Crossfade II Wireless by pressing the + button.
- If the speakers are not working, replace the speaker with [Speaker replacement guide].
0 comentarios
