Traducción no aprobada
Un agradecimiento especial a estos traductores:
100%
¡ Fermin Fernandez nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
100%
Ultimas 24 horas: 1
Ultimos 7 días: 23
Ultimos 30 días: 142
Todo El Tiempo: 45,010
43 comentarios
I've noticed that the bag sensor flaps seem to hang up and cause the machine to malfunction. There's no real was to access these flaps to clean them.
Edward Barcik - Contestar Compartir
Edward, I had the same trouble with the sensor flaps. I’d enter a bag to seal it, hold it straight across… cut off a little of the bag… all the tricks to make it work but it just wouldn’t activate the vacuum sealer. Here’s what I did to fix it.
If you turn the sealer over and open the drawer you’ll see there are two floppy plastic pieces. You’ll also see the seal gasket that the drawer gasket seals press and seal against. If the flappers and seal rings are dirty and gummed up the sealer won’t work.
To clean them used a tooth brush (soft bristle) and brushed the goo off the flaps, top bottom and around the seal rings. I used awesome cleaner to spray the parts/pieces in there to clean the gummed up goo. I found that it got pretty wet from the cleaning but it does dry out with a paper towel or thin cotton rag. I think a Q tip might be helpful cleaning and drying in there too.
gandimoore - Contestar Compartir
Just saved me $150! I had this problem with my 4980 and had bought a replacement when I saw this comment. The new one is going back to Costco.
Bjorn Ingi Magnusson - Contestar Compartir
I’m so glad I found your post. You just saved me a heap of time and money. I also noticed when I was looking at those flaps…one had folded down the wrong way. Cleaned and reset the flaps. The Foodsaver hasn’t worked this good in a long time.
Chased by a Bear - Contestar Compartir
This was great! My machine is like brand new! Thank you muchisimo!
Arthur Martinez - Contestar Compartir
