Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Computer won’t charge
Computer battery won't charge up when plugged in
Computer isn't plugged in correctly
Can be diagnosed by seeing if the cable is securely plugged into the outlet.
- Be sure that the charging cable is plugged securely into a working outlet.
- Be sure the charging cable is inserted into the computer correctly.
Adapter isn't plugged in correctly
See if the part of the cable that plugs into the wall is connected completely to the ‘box-like’ adapter.
- Make sure the cable is plugged into the adapter properly.
Battery doesn't last long
If the computer does seem to charge at first but dies very quickly after disconnected from the power cable.
Computer keeps overheating
Computer is really hot or blue screen
Fan is dusty
A fan that is clogged with dust is unable to circulate air properly. This means that the computer will eventually overheat.
- Make sure computer is off.
- Begin removing the ten screws on the bottom of the computer. Note: Be sure not to lose the screws and remember which screws go where.
- Unscrew the seven screws that are holding the fan in place.
- Unplug fan from motherboard.
- Remove the fan gently from the motherboard.
- Shoot compressed air into the fan to clear dust particles from the fan.
- Put the fan back into place, plug it back onto the motherboard, and put all the screws back into place.
- Place the bottom of the computer back into place and screw it back in.
Inside of computer is dusty
If the inside of a computer is dusty the additional dust adds a layer of insulation, as well as blocking airflow that will cause a computer to run hot.
- Shoot compressed air onto dusty areas of the laptops internal components.
Fan is broken/doesn't turn on
If you cannot hear the fan spooling up when the computer is turned on, the fan is most likely not working.
Computer won’t turn on
When power button is pressed the computer won't turn on
Computer needs to be recharged
Computer won’t turn on when the on/off button is pressed, but the computer is not connected to a power source.
- To recharge a computer plug in the power cable
Power button needs to be held
- Some computers need the power button held to turn on. Try holding the power button for a few seconds
Screen isn't functioning correctly
Blue screen, screen is spotty, pixels are discolored/broken.
- There is a small icon on the bottom right of the inside of the computer of a small lightbulb. See if this light is on.
- If this light is on or the computer sounds like it's on, then it may be a screen issue.
Display isn’t working
The laptop display isn't showing anything
Laptop needs to be turned on
- If this light is on then it’s probably a display issue.
Screen cable may be loose
If the screen cable is loose, it may just need to be resecured, saving a costly screen replacement.
- Check to see if the cable is correctly attached to the motherboard.
Screen needs to be replaced
Can’t connect to wifi
The computer won't connect to local wifi
Wifi button is in off position
- Check if the WIFI symbol on the top left of the keyboard is lit up green. If it is not, press the F2 button.
Router isn't functioning correctly
- Make sure the router is turned on.
- Use an ethernet cable to connect directly to the router. If the Internet is still not working, then the problem is the router.
- If the internet works while the ethernet cable is attached, then the problem lies within the laptop.
0 comentarios
