Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
A defective Wifi card will prevent you from accessing the internet wirelessly. This guide will help replace it to fix this problem. Manipulating wires are necessary so be sure to remember where the wires are unplugged from.
  1. Make sure the computer is turned off.
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Remove the four 5mm Phillips #1 screws from the top of the laptop. Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Lift off the cover and remove the back cover from the device.
    • Lift off the cover and remove the back cover from the device.
  5. Unplug the two small cords connected to the wifi card. Unplug the two small cords connected to the wifi card. Unplug the two small cords connected to the wifi card.
    • Unplug the two small cords connected to the wifi card.
  6. Using a Phillips #1 Screwdriver unscrew the 2 mm screw holding the wifi card in place.
    • Using a Phillips #1 Screwdriver unscrew the 2 mm screw holding the wifi card in place.
  7. Unplug the Wi-Fi card from the motherboard and remove it from the device. Unplug the Wi-Fi card from the motherboard and remove it from the device. Unplug the Wi-Fi card from the motherboard and remove it from the device.
    • Unplug the Wi-Fi card from the motherboard and remove it from the device.
Conclusión
Equipo
USF Tampa, Team S10-G3, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G3, Thompson Fall 2017
USFT-THOMPSON-F17S10G3
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 16
Todo El Tiempo: 296
