Saltar al contenido principal
« Volver a todos los relatos
switch the HDD with a SSD
jmduno -
iMac Intel 27" EMC 2309 and 2374
Imagen del relato
  • Imagen 1
  • Imagen 2
Installing iMac Intel 27" EMC 2309 and 2374 Dual Drive
1 - 2 horas
Moderate
Mi Problema
To increase performance.
Mi Solución
i had the possibility to fix the ssd with 2 screw on the backside of the Optical Bay, so i did.
I was not able to put back the last screw of step 15 ( Instalación de iMac Intel de 27" EMC 2309 y 2374 de doble unidad ) on the optical bay.
A little pain about reconnecting the optical sensor in the good way.
I disassembly the computer up on his feet, but for put back the screen, I had to put the computer down Because, the screw holes was not aligned correctly due to the weight of the screen.
the vertical sync ribbon cable is the main tricky part of the reassembly. It's hard to reconnect it.
Mi Consejo
I loved the Magnetic Project Mat ! So use it !
Imagen de iMac & Mac mini Dual Drive Enclosure
$19.99
Imagen de Heavy-Duty Suction Cups (Pair)
$16.95
Imagen de Magnetic Project Mat
$19.95
Imagen de Pro Tech Toolkit
Pro Tech Toolkit
$79.95
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 64
