Saltar al contenido principal
« Volver a todos los relatos
Power supply replacement
lazzeostergaard -
Imagen del relato
  • Imagen 1
  • Imagen 2
  • Imagen 3
Mi Problema
I bought an Imac 24 on the Swedish ebay "Tradera" guessing that there was a problem with the power supply. Thanks to the guide here on ifixit I thought that I give it a try so I ordered a new power supply, 3 screwdrivers and suction cups.
Mi Solución
Thanks to the guide on ifixit i managed to replace the power supply in half an hour. I was very excited when I first pressed the power button and I could here the apply startup sound, however, the power supply was not the only part that was corrupt. The hard drive was also bad so I had to take the Imac apart one more time to replace the hard drive (had one 1 TB laying around).
Mi Consejo
It is a good idea to be 2 persons doing this repair. If one can hold the LCD you don't even need to disconnect the LCD. That will save you some time.
Imagen de T6 Torx Screwdriver
T6 Torx Screwdriver
$9.99
Imagen de Heavy-Duty Suction Cups (Pair)
$16.95
Imagen de TR10 Torx Security Screwdriver
$5.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 54
