Saltar al contenido principal
« Volver a todos los relatos
Petzl Headlight button repair
Gavriil Kamaris -
Imagen del relato
  • Imagen 1
  • Imagen 2
Mi Problema
The rubber covering the On?Off button was destroyed after years. The PCB was revealed making the circuit vulnerable to dust and moisture and the button difficult to locate.
Mi Solución
I cut a transparency slide oval part to avoid the glue going all over and create a spring like behavior and also designed and 3D printed a small pin to push the button. Then i covered the assembly with mouldable glue (like sugru) to reform the rubber cover. All went well and the button is working fine
Mi Consejo
Please contact me if you need any designs for the 3d print pin.
1 comentario
Well done! 👌Will come back to this when my Petzl button fails
Susanne - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 257
