Saltar al contenido principal
« Volver a todos los relatos
iMac SSD Upgrade
Carl Hill -
iMac Intel 27" EMC 2639
Imagen del relato
  • Imagen 1
  • Imagen 2
  • Imagen 3
iMac Intel 27" EMC 2639 Hard Drive Replacement
2 Hora
Moderate
Mi Problema
The oem 2TB HDD was just full and unable to boot. Opted to upgrade to SSD and reinstall OS.
Mi Solución
Everything well very well. The kit was well worth the money as I likely would have failed without it. The new adhesive is easy to work with, the foam brace makes things easy and the SSD Temp sensor likely would have been forgotten if I hadn't just purchased this kit.
Mi Consejo
Removing the screen can be tricky but just keep cutting and prying gently and slowly and it will come out. Removing and routing the cables around the HDD can be tricky but again just don't force anything and be patient.
Imagen de iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
$115.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 271
