Saltar al contenido principal
« Volver a todos los relatos
MacBook Pro USB port fixed!
David C Black -
MacBook Pro 15" Retina Display Mid 2012
Imagen del relato
  • Imagen 1
  • Imagen 2
  • Imagen 3
MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement
1 Hora
Difficult
Mi Problema
USB port was completely unresponsive despite several software reset and other attempts.
Mi Solución
Everything was quite straightforward with the guide; however, one aspect was not documented. The I/O board *data* cable replacement has no guidance. After looking at the problem, and because I did not have reason to suspect it was broken, we decided to forgo replacement. The decision was correct. Unfortunately, that means we spent an extra $19 we did not need -- it had been obtained because the parts list indicated it was necessary. We had opened the parts packages up before starting. So I am not sure it can be returned; although, as a simple cable it is unlikely we could have damaged it.
On the other hand, the I/O board cable was needed as it is fairly fragile and removal may or may not leave it in a decent condition.
Mi Consejo
Buy some double sided tape to help stick parts back down.
I have some photos detailing routing of the camera/airport cable.
Be careful not to cover the I/O board data cable as you put the I/O board back. I had to remove the board to extract the hidden cable.
The iFixit magnetic board helped a lot to keep screws in the right place. Be sure to put them on the board in a manner that helps you know which goes where.
Imagen de MacBook Pro 15" Retina (Mid 2012-Early 2013) Right I/O Board
$34.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 330
