Saltar al contenido principal
« Volver a todos los relatos
Sony a65 Main board replacement
HITGFRY -
Imagen del relato
Mi Problema
Camera would not power up. I found that the CMOS battery receptacle solder points had come undone. I tried to re-solder but it didn't work. I think the poor connection damaged something else in the mother board. I purchased a manufacturers refurbished MB on eBay for $159.00.
Mi Solución
Replaced the main board. It went well but not as fast as the tutorial said but that's to be expected first time through.
Mi Consejo
DO NOT install the CMOS battery until last thing before you put the plastic covers back on. The battery receptacle will break very easily if you ham hand the battery installation, I broke a tab but was able to secure it with super glue. Make sure you put screws on a non-metallic tray with a lip so they won't roll away and lay them out in order as they are removed.
Imagen de iFixit Precision 4 mm Screwdriver Bit
$2.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 388
