Saltar al contenido principal
« Volver a todos los relatos
iPhone 5s Battery Replacement
Tom -
iPhone 5s
Imagen del relato
  • Imagen 1
  • Imagen 2
  • Imagen 3
How to replace the battery in your iPhone 5s
30 Minuto - 1 Hora
Moderate
Mi Problema
The battery went dead very fast.
Mi Solución
Removing the battery was incredibly difficult. I installed the new battery but had to put phone back together 5 times before I could get the screen to work. I had no problem with parts I got from iFixit.
Mi Consejo
When removing the battery try not to fold the battery at all. If the battery folds it can cause a short and explode in your phone this is what happens when trying to remove it. Try to make sure your battery is dead all the way before you change it.
Imagen de iPhone 5s Battery
iPhone 5s Battery
$29.99
3 comentarios
The 5S battery is a real pain to remove. at th ebottom of the battery is a black plastic tab that you can pull on to remove the adhesive holding the battery in place, but 9/10 time it rips off without removing the adhesive.
The only way I have found to get the battery out without it bending too much, is to use a heat gun and heat up (not too much!!) the back of the phone where the battery is sitting. Then use a thin flat spudger or similar to get under the battery. Normally the battery casing rips as the glue holding it in place is overkill on Apple's part.
Harvey - Contestar Compartir
When you first remove the dock connector, you can really easy pull the black plastic tape without breaking it.
Marvin - Contestar Compartir
Tom,
Im sorry you had a difficult time replacing the battery on your iPhone 5s. For first timers it can be a bit tricky. For future repairs on your mobile devices by all means contact me for help or advice just click on my name gillrios to get me email and contact info for my business G3 Mobile.
gillrios - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 647
