Saltar al contenido principal
« Volver a todos los relatos
Power Supply Replacement
Brandon Dusseau -
iMac Intel 27" EMC 2309 and 2374
Imagen del relato
  • Imagen 1
  • Imagen 2
  • Imagen 3
iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement
10 Minuto
Easy
Mi Problema
The power supply was buzzing.
Mi Solución
The repair was super easy and straightforward. It helped that I had taken apart an iMac before and so I already knew the procedure for removing the LCD.
Mi Consejo
It helps to unscrew the power supply first to make it easier to reach the locking clip underneath for the power distribution cable. if you don't want to buy suction cups, the suction cup that comes with a GPS or other windshield-mounted car accessory works like a charm (but be careful not to stress the glass too much by only using the one cup).
Imagen de iMac Intel 27" EMC 2309, 2374, 2390 or 2429 Power Supply
$139.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 474
