Saltar al contenido principal
« Volver a todos los relatos
MacBook Pro surgery
Enrico Barbieri -
Electronics Skills
Imagen del relato
  • Imagen 1
  • Imagen 2
  • Imagen 3
How to Apply Thermal Paste
5 - 20 minutos
Moderate
Mi Problema
My MacBook fans will always run at max speed while using heavy apps like VMware Fusion. The situation was critical mainly because of the noise of fans running at 6200rpm
Mi Solución
The repair went well... I opened the MacBook without any particular issue thanks to the heat sink replace guide provided by iFixt. Just moving really slowly because I was afraid of broking some contacts and mess up everything...
Mi Consejo
Repair is basically easy even if you need to disassemble half of your MacBook... Watch out for cables and plug while you put logic board in place... If it does not fit perfectly there are some cables on your way
Imagen de iFixit Thermal Paste
$24.95
Imagen de Arctic Silver ArctiClean
$11.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 82
