Battery stuck in MacBook
I have tried pulling the release tabs, but the battery won't come out. (I have done it before so I know what it should do)
Is there any other way I can get it out?
Thanks ver much.
Es esta una buena pregunta?
Thanks ver much.
Nevermind my last post about what kind of macbook. I am just gonna assume its a MacBook Pro since you said "latches". This usually happens because of the battery swelling and pushing against the sides of the slot where the battery is. In the past i have solved this issue by pulling both the tabs at once and taking a spudger which is sold on this site, you can also use anything that is a dull plastic (do not use anything sharp it is a battery and that could be dangerous) and pry in between the case and the battery. The side of the battery nearest the latches with be the part you want to pry on which i assume you know since you said you have replaced the battery before. Let me know what you get.
Fue útil esta respuesta?
Thanks Chris.
Took into Mac retailer and they did as you said, but with two wallpaper scrapers!
Having said that, it took four of us to get it out. The plastic bit on the battery where it connects to the pins had cracked and was caught.
Anyway, working on mains so at least up and running again.
Thanks for the reply.
Much appreciated!
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 4,416
