Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Acer One 10 S1003-114M es un convertible, lo que le permite funcionar tanto como una tableta como un portátil.
Display doesn't power on
On my Acer One 10 S1003-114M I have installed incorrect graphics drivers then the device when off, since then has never powered on again, but when I plug a charger cable I can see the charging light, please help on how to fix this issue. Thank you in advance.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Your Acer One 10 likely entered a deep power-state glitch or suspended state (a "soft brick") due to the incorrect graphics driver. You can fix this by performing an internal battery reset to clear the system's memory and force a proper boot. Post your question in your browser and the AI will give you the details.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks a lot I will do it you mentioned.
- de
Añadir tu respuesta
ZANDILE GRACE estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 23
Todo El Tiempo: 138
