Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una mascota digital portátil que se vendió por primera vez en Japón en 1996.
Disconnected Wires; Soldering Necessary?
Hello! I've taken my old Tamagotchi apart for repairs, but it seems one of the little wires popped off the... speaker cell? The little round part that is not the battery. Do I need to solder it back on? If yes, what soldering kit should I get? I know I would need something with an extremely small tip, but I have never soldered anything before. Is there a certain temperature to use? Anything else I need to know about soldering small things?
For clarification's sake, one of the white wires in this picture is what has detached.
Thank you for reading!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I think it will need to be soldered back on. I'm not too knowledgeable on soldering, but I was able to find a written web guide on soldering small electronics (from Excel blades) that gives what looks like a good materials list. The old solder should probably be desoldered and removed from the plate as well. Also, that type of speaker is apparently called a Piezo Buzzer. How fun!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
CaptainCassidy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 48
