Saltar al contenido principal
Reparar información en unidades de disco o discos duros. Los discos duros son dispositivos magnéticos de almacenamiento de datos. Se utilizan en la mayoría de las computadoras de escritorio, portátiles y servidores debido a su bajo costo y alta densidad de datos.
Preguntas 20 Ver todo
Unable to Format 30 GIG Quantum Fireball Plus hard drive?
I had a working 30 GIG Quantum Fireball Plus hard drive. I need to install it in a iMac G3 233 to donate. I tried to partition the first 8GIGs at 7.5 to be able install the system correctly. The partitioning failed with a "Resource busy" error. Then tried a standard OSX extended format, same error. Then tried a zero all data and I get:
Disk Erase failed with the error:
Resource busy
I have it in an external Firewire enclosure, hooked to a G5 MacPro 2.0GHz DP. Any ideas?
Thanks
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Richard i"m not sure this will help but the consensus I get reading on this issue you need to unmount the partitions and then proceed with your formating. I know you are a very knowledgeable searcher but am going to include one of many URL's that I found on the subject. Hope this is of some help. Ralph
http://www.macosxhints.com/article.php?s...
http://hints.macworld.com/comment.php?mo...
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Thanks for the work. + the partitioned volume disappeared when the partition failed. If I unmount now There will be noting to work with.
- de
Hi, digging around a little more I found a suggestion that by using an earlier version of the OS (i/e 10.3) you could do what you need to do. I don't know if it would work but you can try. Ralph
- de
Thanks Ralph. You & I seem to be the only ones that kn ow about these old babies. Will have to find a 10.3 machine. Will let you know.
- de
Añadir tu respuesta
mayer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,761
