What is this sound coming from my washer during the cycle?
Washing machine is making this weird sound during spin cycle and then when venting it’s like a low rattle. Anyone know what it is? Thanks in advance.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
4 comentarios:
Your video didn’t post.
- de
@ladytech Ah thank you for the heads up. I tried re-uploading it several times and did a 8 second one and yet it still isn't uploading. Have you had this issue before?
- de
@andreioanca
What's the model number of the washer?
- de
@andreioanca It could be something in the drain pump or the pump bearings are worn. It could be the rear spider gear. If the spider gear developed a crack it will make all kinds of different noises. We need more details and information on the washer to be more helpful. Is it washing, draining, spinning, completing cycles, or showing any error codes? The model number is on the inside of the door or around the opening of the tub.
- de
Agregar un comentario
