Saltar al contenido principal
The DeWalt DW311 is a corded reciprocating saw.
How to replace power cord?
The black cord seems to be hard wired into the switch. How to separate and replace just the cord?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
@alienamerican looks like the power cord is available without the switch. That would mean that it is somehow possible to remove the cable from the switch. I wonder if there is a push connector on the switch for the cable. Post some good pictures of your switch etc. with your Question. That way we can see what you see and hopefully come up with a solution. Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
Added some photos. This little black box looks like it should open, but nothing I've tried seems to work
- de
@alienamerican what a PITA. I absolutely dislike when they make things so complicated. Yes, it does look like it comes out. The trigger seems to operate some sort of lever that moves the contacts on the inside of the switch. Honestly, at this point I would just cut the wires, solder the new power cord to the tails and apply some heat shrink tubing for insulation.
- de
Good idea. I'm gonna just do that
- de
Añadir tu respuesta
Alienamerican estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 102
