How do I pair it with an echo pop via Bluetooth?
Quite a few devices with identical names appear in the available device list. Trial and error has not produced a successful pairing.
Es esta una buena pregunta?
Hi @jcg65641
Check if an available device disappears from the BT list in the tablet if you turn the Echo Pop off. That one should appear again when you turn it back on again
BT only works well within 33' (10M) further than that not so good if at all, so the closer you stand next to the Echo Pop with the tablet when pairing the more reliable the connection.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 37
