Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
A Dell XPS 15" 9575 (2 in 1) laptop, manufactured in 2018.
How to replace internal keyboard?
I’m asking because I don’t know what to do at the stage when you see black polyethylene. I can’t find the complete replacement instructions.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @galaxyvitas1143
Here's the service manual, taken from this support webpage for the laptop.
Go to p.52 to view the procedure to remove the palm rest and keyboard assembly.
Basically you have to nearly completely disassemble the laptop to do this.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Well, the instructions only show the entire keyboard block with the case. I just want to replace the keys inside
https://imagizer.imageshack.com/img923/4...
- de
@galaxyvitas1143
You'll probably find that the keyboard is fused or riveted to the upper case, so you will have to either melt the plugs or drill out (break) the rivets that are holding the keyboard in place.
- de
Añadir tu respuesta
Galaxyvitasa Galaxyvitasa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 23
Todo El Tiempo: 253
