Can't see wifi Connection. what would I do
Can't see wifi Connection. what would i do
Es esta una buena pregunta?
If your phone can't see a Wi-Fi connection, the first steps are to check if your phone's Wi-Fi is turned on, ensure you're not in airplane mode, and then try restarting your phone and router; if that doesn't work, you can try forgetting the network and reconnecting, checking for network updates, or even resetting your network settings on your phone.
Fue útil esta respuesta?
Hi @arjie
Try using the phone's WiFi as close as possible to your home network router i.e. <10cm and check if it detects and connects to the network and if the connection remains stable.
If it does, there may be an antenna problem in the phone e.g. loose or faulty.
Here's an image taken from this teardown video showing the antenna connections.
(click on image)
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 18
