How do I boot into bios
Every google result tells me how to boot into bios on a normal laptop, with function keys. This laptop doesn't have those.
An answer would be appreciated. Thanks.
Es esta una buena pregunta?
Hi @jeff___
Chromebooks don't have a BIOS like other PCs as they use the Chrome OS to function
Here's a link that describes it better than I can.
Fue útil esta respuesta?
Hi Jayeff,
Thank you for your response.
Is there an equivalent that is available on Chrome OS?
Thanks
(W name btw)
@jayeff above
I do have one. The post that you attached does not mention anything about using another device. How would I use another device to get the BIOS of my Chromebook?
Thanks.
I meant that to access the BIOS in the laptop, it needs to be working i.e. able to be turned on and the OS loaded OK etc.
My comment was based on that you asked another question, previous to this one, on the same day, for the same model, where you said that it will not boot.
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 91
