Saltar al contenido principal
La actualización de marzo de 2015 del MacBook Air de 13" de Apple presenta procesadores Intel Core i5 e i7 de quinta generación, lo que resulta en un rendimiento ligeramente mayor y una mayor duración de la batería.
Preguntas 20 Ver todo
Trying in install a new SSD
Hi,
I have an MacBook Air 13" Early 2015, A1466 EMC2925
I installed a PCIe Gen3 x 4 / 3D NAND Flash for Mac SSD (6+12Pin), but it is not seen.
What did I wrong?
I have updated Mojave on the original drive before (firmware 489....), then replaced this with the new SSD.
When booting in Recoverymode, then use the diskutil, it is NOT listed.
SMC reset and NVRAM reset also done.
I have no idea what to do .... maybe you can help me.
Thx
Es esta una buena pregunta?
Puntuación 0
1 comentario
Why not install OSX Monterey?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
You really need a bootable external drive with the correct macOS which supports NVMe drives.
Using a second Mac download the macOS installer from here Update macOS on Mac and from here How to download and install macOS.
Personally I like to create a bootable USB thumb drive. Make sure you reformat the thumb drive to GUID with a Journaled File System. Then copy the OS installer onto the drive and follow this Create a bootable installer for macOS
Now using this drive boot up your system accessing its copy of Disk Utility do you see the drive now?
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thx Dan, this helped a lot.
I didnt know, that in the beginning of the installtion of a new MacOS you reach the diskutil too. At this point the drive is listed :-)
cheers
Ralf
- de
Añadir tu respuesta
RaRom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 31
